[postgis-tickets] [PostGIS] #5237: postgis_extensions_upgrade fails with ERROR: there is no unique or exclusion constraint matching the ON CONFLICT specification
PostGIS trac at osgeo.org
Mon Sep 12 08:00:45 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.3.2
 Component:  postgis  |    Version:  3.3.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Actual error was on a french system with below and mentioned in IRC by a
> DoctorWho80
> ERREUR:  il n'existe aucune contrainte unique ou contrainte d'exclusion
> correspondant à la spécification ON CONFLICT
> We traced the issue down to missing unique constraint on spatial_ref_sys.
> the fix was to do
> ALTER TABLE IF EXISTS spatial_ref_sys ADD CONSTRAINT spatial_ref_sys_pkey
> PRIMARY KEY (srid);
> and then rerun:
> SELECT postgis_extensions_upgrade();
> It is unclear if the issue was at a time postgis did not have a primary
> key on this table, or that some time ago whoever was managing this
> database explicitly removed the primary key.
> If it is our fault (might be good to do anyway), we should guard against
> it by adding the primary key if we find it does not exist.
> This is only an issue for PostGIS 3.3+ because prior versions do not try
> to load missing spatial_ref_sys records.
New description:
 DoctorWho80
 NOTICE:  Updating extension postgis from 3.1.1 to 3.3.1
 CONTEXTE : instruction SQL « ALTER EXTENSION postgis UPDATE TO "3.3.1"; »
 fonction PL/pgSQL postgis_extensions_upgrade(), ligne 79 à EXECUTE
 the fix was to do
 PRIMARY KEY (srid);
 and then rerun:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5237#comment:2>
