[postgis-tickets] [PostGIS] #5201: upgrade-path branch fails on windows
PostGIS trac at osgeo.org
Wed Sep 14 06:36:14 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 And to answer your question: the `postgis install-upgrade-paths` call
 would only ever install <from>--ANY files. Full help string for that
 command, as reported by `postgis help`:
   install-extension-upgrades [--pg_sharedir <dir>] [<from>...]
                 Ensure files required to upgrade PostGIS from
                 the given version are installed on the system.
                 The <from> arguments may be either version numbers
                 or PostgreSQL share directories to scan to find available
                 ones.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5201#comment:6>
