[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-93-g97903f899
Thu Sep 15 11:17:23 PDT 2022
the project "PostGIS".
       via  97903f89960c8079e8edf9c9b9db74dd66c1e194 (commit)
      from  9261883feaf369689d1ea2871eddf6ebcbf1b6ad (commit)
revisions in full, below.
commit 97903f89960c8079e8edf9c9b9db74dd66c1e194
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 15 20:11:45 2022 +0200
    Do not hide preprocessor bugs
    See
    https://github.com/postgis/postgis/pull/706#issuecomment-1248389918
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 73d084254..9c12a4e4d 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -65,7 +65,8 @@ sql:
 # Borrow the $libdir substitution from PGXS but customise by running the preprocessor
 # and adding the version number
 sql/%.sql: %.sql.in | sql
-	$(SQLPP) -I at buiddir@/../libpgcommon $< | grep -v '^#' | \
+	$(SQLPP) -I at buiddir@/../libpgcommon $< > $@.tmp
+	grep -v '^#' $@.tmp | \
 	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
 %.control: %.control.in Makefile
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 6fd828247..5d1473f6c 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -135,7 +135,8 @@ sql/postgis_upgrade_for_extension.sql.in: sql/postgis_for_extension.sql ../../ut
 	$(PERL) @top_srcdir@/utils/create_upgrade.pl $< > $@
 sql/postgis_for_extension.sql: ../../postgis/postgis.sql.in ../../postgis_revision.h | sql
-	$(SQLPP) -I at builddir@/../../postgis $< | grep -v '^#' | \
+	$(SQLPP) -I at builddir@/../../postgis $< > $@.tmp
 	$(PERL) -lpe \
 		"s'MODULE_PATHNAME'\$(MODULEPATH)'g" \
 		| $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' > $@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 33cb4f250..a1d4ad613 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -93,7 +93,8 @@ sql/rtpostgis.sql: sql/rtpostgis_for_extension.sql | sql
 	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
 sql/rtpostgis_for_extension.sql: ../../raster/rt_pg/rtpostgis.sql.in ../../postgis_revision.h | sql
-	$(SQLPP) -I at builddir@/../../postgis/ -I../../ $< | grep -v '^#' | \
+	$(SQLPP) -I at builddir@/../../postgis/ -I../../ $< > $@.tmp
 sql/rtpostgis_upgrade.sql: sql/rtpostgis_upgrade_for_extension.sql | sql
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index be8bd5755..b5aef0768 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -237,8 +237,9 @@ endif
 # replace @extschema at . with nothing, this is only used as placeholder for extension install
 %.sql: %.sql.in
-	$(SQLPP) -I at top_srcdir@/libpgcommon -I at builddir@ $< | grep -v '^#' | \
-	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
+	$(SQLPP) -I at top_srcdir@/libpgcommon -I at builddir@ $< > $@.tmp
+	grep -v '^#' $@.tmp | $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
+	rm -f $@.tmp
 #this is redundant but trying to fold in with extension just hangs
 postgis_upgrade.sql.in: postgis.sql ../utils/create_upgrade.pl
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index ae70a859e..8146f66da 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -125,7 +125,8 @@ endif
 %.sql: %.sql.in
-	$(SQLPP) -I at top_builddir@/postgis/ $< | grep -v '^#' | \
+	$(SQLPP) -I at top_builddir@/postgis/ $< > $@.tmp
 ../../liblwgeom/.libs/liblwgeom.a:
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 9504ead5b..b003d1b89 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -122,7 +122,8 @@ $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
 %.sql: %.sql.in
-	$(SQLPP) -I at top_builddir@/postgis $< | grep -v '^#' | \
+	$(SQLPP) -I at top_builddir@/postgis $< > $@.tmp
 sfcgal_upgrade.sql.in: sfcgal.sql ../utils/create_upgrade.pl
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 9b53bf98f..4315df092 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -102,7 +102,8 @@ endif
 # Generate any .sql file from .sql.in files by running them through the SQL pre-processor
 %.sql: %.sql.in
 #Generate upgrade script by stripping things that can't be reinstalled
Summary of changes:
 extensions/address_standardizer/Makefile.in | 3 ++-
 extensions/postgis/Makefile.in              | 3 ++-
 extensions/postgis_raster/Makefile.in       | 3 ++-
 postgis/Makefile.in                         | 5 +++--
 raster/rt_pg/Makefile.in                    | 3 ++-
 sfcgal/Makefile.in                          | 3 ++-
 topology/Makefile.in                        | 3 ++-
 7 files changed, 15 insertions(+), 8 deletions(-)
hooks/post-receive
