[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-106-gb7b6ab74a
Fri Sep 16 14:43:26 PDT 2022
the project "PostGIS".
       via  b7b6ab74aeeb24c825813e6f3e3e62b3d2356df6 (commit)
      from  5698f9b0b4565bb57cdc82b8f77a0120d380a9ba (commit)
revisions in full, below.
commit b7b6ab74aeeb24c825813e6f3e3e62b3d2356df6
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 16 23:43:16 2022 +0200
    Don't leave .tmp files behind
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 20bd88ff5..0964ea1b0 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -68,6 +68,7 @@ sql/%.sql: %.sql.in | sql
 	$(SQLPP) -I at buiddir@/../libpgcommon $< > $@.tmp
 	grep -v '^#' $@.tmp | \
 	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
+	rm $@.tmp
 %.control: %.control.in Makefile
 	cat $< \
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 5d1473f6c..404fb6686 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -140,6 +140,7 @@ sql/postgis_for_extension.sql: ../../postgis/postgis.sql.in ../../postgis_revisi
 	$(PERL) -lpe \
 		"s'MODULE_PATHNAME'\$(MODULEPATH)'g" \
 		| $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' > $@
+	rm $@.tmp
 sql/postgis_upgrade.sql: sql/postgis_upgrade_for_extension.sql | sql
 	$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index a1d4ad613..64eec13be 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -96,6 +96,7 @@ sql/rtpostgis_for_extension.sql: ../../raster/rt_pg/rtpostgis.sql.in ../../postg
 	$(SQLPP) -I at builddir@/../../postgis/ -I../../ $< > $@.tmp
+	rm $@.tmp
 sql/rtpostgis_upgrade.sql: sql/rtpostgis_upgrade_for_extension.sql | sql
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index b5aef0768..60e0a486f 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -239,7 +239,7 @@ endif
 %.sql: %.sql.in
 	$(SQLPP) -I at top_srcdir@/libpgcommon -I at builddir@ $< > $@.tmp
 	grep -v '^#' $@.tmp | $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
-	rm -f $@.tmp
+	rm $@.tmp
 #this is redundant but trying to fold in with extension just hangs
 postgis_upgrade.sql.in: postgis.sql ../utils/create_upgrade.pl
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index 8146f66da..53cc52166 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -128,6 +128,7 @@ endif
 	$(SQLPP) -I at top_builddir@/postgis/ $< > $@.tmp
+	rm $@.tmp
 ../../liblwgeom/.libs/liblwgeom.a:
 	$(MAKE) -C ../../liblwgeom
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index b003d1b89..c8019332b 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -125,6 +125,7 @@ $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
 	$(SQLPP) -I at top_builddir@/postgis $< > $@.tmp
+	rm $@.tmp
 sfcgal_upgrade.sql.in: sfcgal.sql ../utils/create_upgrade.pl
 	$(PERL) @top_srcdir@/utils/create_upgrade.pl $< > $@
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 4315df092..842de0933 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -105,6 +105,7 @@ endif
+	rm $@.tmp
 #Generate upgrade script by stripping things that can't be reinstalled
 #e.g. don't bother with tables, types, triggers, and domains
Summary of changes:
 extensions/address_standardizer/Makefile.in | 1 +
 extensions/postgis/Makefile.in              | 1 +
 extensions/postgis_raster/Makefile.in       | 1 +
 postgis/Makefile.in                         | 2 +-
 raster/rt_pg/Makefile.in                    | 1 +
 sfcgal/Makefile.in                          | 1 +
 topology/Makefile.in                        | 1 +
 7 files changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
