[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-109-g92b3ff24e
Sat Sep 17 06:49:57 PDT 2022
the project "PostGIS".
       via  92b3ff24e095872e9fcd3d2bef2a8a622c7a1c15 (commit)
      from  55aa90628a9f4d233dbe90b55cf0e621f7f98a3d (commit)
revisions in full, below.
commit 92b3ff24e095872e9fcd3d2bef2a8a622c7a1c15
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Sep 17 15:49:38 2022 +0200
    Allow installing upgrade paths for a single extension
    Fixes make install
diff --git a/extensions/upgrade-paths-rules.mk b/extensions/upgrade-paths-rules.mk
index 1a386c81b..3189960fb 100644
--- a/extensions/upgrade-paths-rules.mk
+++ b/extensions/upgrade-paths-rules.mk
@@ -25,6 +25,7 @@ install-upgrade-paths: tag-as-any
 	ln -fs "$(TAG_UPGRADE)" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--ANY.sql; \
 	$(abs_topbuilddir)/loader/postgis \
 		install-extension-upgrades \
+		--extension $(EXTENSION) \
 		--pg_sharedir $(PG_SHAREDIR) \
 		$(UPGRADEABLE_VERSIONS)
diff --git a/loader/postgis.pl b/loader/postgis.pl
index 013d8c4ca..6c5509699 100644
--- a/loader/postgis.pl
+++ b/loader/postgis.pl
@@ -21,7 +21,7 @@ Commands:
   enable <database>  enable PostGIS in given database
   upgrade <database> upgrade PostGIS in given database
   status <database>  print PostGIS status in given database
-  install-extension-upgrades [--pg_sharedir <dir>] [<from>...]
+  install-extension-upgrades [--pg_sharedir <dir>] [--extension <name>] [<from>...]
 		Ensure files required to upgrade PostGIS from
 		the given version are installed on the system.
 		The <from> arguments may be either version numbers
@@ -31,28 +31,36 @@ Commands:
+my %SUPPORTED_EXTENSIONS = (
+	'address_standardizer' => 1,
+	'postgis' => 1,
+	'postgis_raster' => 1,
+	'postgis_sfcgal' => 1,
+	'postgis_tiger_geocoder' => 1,
+	'postgis_topology' => 1
 sub install_upgrade_from
-	my ( $SHAREDIR, $from ) = @_;
+	my ( $SHAREDIR, $EXTENSION, $from ) = @_;
 	#print "SHAREDIR: $SHAREDIR\n";
 	#print "FROM: $from\n";
 	die "Please specify a sharedir and a version to install upgrade support for.\n"
 		unless $from;
-	my %supported_extension = (
-		'postgis' => 1,
-		'postgis_raster' => 1,
-		'postgis_sfcgal' => 1,
-		'postgis_tiger_geocoder' => 1,
-		'postgis_topology' => 1
 	# sanify ${from}
 	die "'${from}': invalid version, only 3 dot-separated numbers optionally followed by alphanumeric string are allowed\n"
 		unless $from =~ /^[0-9]*\.[0-9]*\.[0-9]*[a-z1-9]*/;
 	# Reserver versions
+	my %supported_extension = %SUPPORTED_EXTENSIONS;
+	if ( defined($EXTENSION) ) {
+		%supported_extension = (
+			$EXTENSION => 1
 	my $EXTDIR = ${SHAREDIR} . '/extension';
@@ -87,7 +95,7 @@ sub install_upgrade_from
 sub install_upgrade_from_available
-	my ($SHAREDIR) = @_;
+	my ($SHAREDIR, $EXTENSION) = @_;
 	#print "EXTDIR: ${EXTDIR}\n";
@@ -100,7 +108,7 @@ sub install_upgrade_from_available
 		my $ver = $1;
 		next if $ver eq 'unpackaged'; # we don't want to install upgrade from unpackaged
 		print "Found version $ver\n";
-		return $rv if my $rv = install_upgrade_from $SHAREDIR, $ver;
+		return $rv if my $rv = install_upgrade_from $SHAREDIR, $EXTENSION, $ver;
 		#return $rv if $rv; # first failure aborts all
 	closedir($d);
@@ -113,6 +121,7 @@ sub install_extension_upgrades
 	my $DEFSHAREDIR = `pg_config --sharedir`;
 	chop($DEFSHAREDIR);
 	my $SHAREDIR = ${DEFSHAREDIR};
+	my $EXTENSION;
 	my @ver;
@@ -125,11 +134,19 @@ sub install_extension_upgrades
 			die "$SHAREDIR is not a directory" unless -d ${SHAREDIR};
 			next;
+		elsif ( $_[$i] eq '--extension' )
+			$i++ < @_ - 1 || die '--extension requires an argument';
+			$EXTENSION = $_[$i];
+			die "$EXTENSION is not a supported extension"
+				unless ( exists( $SUPPORTED_EXTENSIONS{$EXTENSION} ) );
+			next;
 		push @ver, $_[$i];
-	print "Installation target: ${SHAREDIR}\n";
+	print "Installation target: ${SHAREDIR} ${EXTENSION}\n";
 	if ( 0 == @ver )
@@ -142,9 +159,9 @@ sub install_extension_upgrades
 		my $v = $_;
 		if ( -d $v ) {
-			install_upgrade_from_available($SHAREDIR, $v);
+			install_upgrade_from_available($SHAREDIR, ${EXTENSION}, $v);
 		} else {
-			install_upgrade_from($SHAREDIR, $v);
+			install_upgrade_from($SHAREDIR, ${EXTENSION}, $v);
Summary of changes:
 extensions/upgrade-paths-rules.mk |  1 +
 loader/postgis.pl                 | 47 ++++++++++++++++++++++++++-------------
 2 files changed, 33 insertions(+), 15 deletions(-)
hooks/post-receive
