[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-114-g4194f0f24
Sat Sep 17 14:05:24 PDT 2022
the project "PostGIS".
       via  4194f0f24df7e1bc7e8655b561f9fdf3646e8a4a (commit)
       via  14807d5ca91e9983af3d51a02138bf7c17a8b51c (commit)
      from  1c0838e7899de623ef842fd2dd5b2cb29b84076b (commit)
revisions in full, below.
commit 4194f0f24df7e1bc7e8655b561f9fdf3646e8a4a
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Sep 17 23:05:15 2022 +0200
    Quote and hush
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 92012a988..3c635947b 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -12,7 +12,7 @@ BUILDDIR=$PWD # TODO: allow override ?
 cd $(dirname $0)/..
 SRCDIR=$PWD # TODO: allow override ?
-cd -
+cd - > /dev/null
 if test "$1" = "-s"; then
@@ -226,7 +226,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   # Check unpackaged->unpackaged upgrades
   CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
-  if test ${to_version} = "${CURRENTVERSION}"; then
+  if test "${to_version}" = "${CURRENTVERSION}"; then
     for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`
     do #{
       UPGRADE_PATH="unpackaged${majmin}--:auto"
commit 14807d5ca91e9983af3d51a02138bf7c17a8b51c
Date:   Sat Sep 17 23:05:06 2022 +0200
    Fix :auto handling (chop)
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 11d144952..ffb83042b 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -243,6 +243,7 @@ psql -XtAc "
 	WHERE name = 'postgis'
 " template1
+chop $defextver;
 my $dbcount = @dblist;
Summary of changes:
 regress/run_test.pl         | 1 +
 utils/check_all_upgrades.sh | 4 ++--
 2 files changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
