[postgis-tickets] [PostGIS] #5246: bessies failing on upgrade
PostGIS trac at osgeo.org
Mon Sep 19 19:12:24 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 Bessies do not like these recent upgrade changes.
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/3980/consoleFull
 1:54:49 ln -fs "postgis--TEMPLATED--TO--ANY.sql"
 /usr/local/share/postgresql/extension/postgis--3.4.0dev--ANY.sql; \
 21:54:49
 /usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f24ef85568c1c38b81b36cbceab60d298d103dab/loader/postgis
 21:54:49        install-extension-upgrades \
 21:54:49        --extension postgis \
 21:54:49        --pg_sharedir /usr/local/share/postgresql \
 21:54:49        2.0.0 2.0.1 2.0.2 2.0.3 2.0.4 2.0.5 2.0.6 2.0.7 2.1.0
 2.1.1 2.1.2 2.1.3 2.1.4 2.1.5 2.1.6 2.1.7 2.1.8 2.1.9 2.2.0 2.2.1 2.2.2
 2.2.3 2.2.4 2.2.5 2.2.6 2.2.7 2.2.8 2.3.0 2.3.1 2.3.2 2.3.3 2.3.4 2.3.5
 2.3.6 2.3.7 2.3.8 2.3.9 2.3.10 2.3.11 2.4.0 2.4.1 2.4.2 2.4.3 2.4.4 2.4.5
 2.4.6 2.4.7 2.4.8 2.4.9 2.4.10 2.5.0 2.5.1 2.5.2 2.5.3 2.5.4 2.5.5 2.5.6
 2.5.7 2.5.8 3.0.0 3.0.1 3.0.2 3.0.3 3.0.4 3.0.5 3.0.6 3.0.7 3.1.0 3.1.1
 3.1.2 3.1.3 3.1.4 3.1.5 3.1.6 3.1.7 3.2.0 3.2.1 3.2.2 3.2.3 3.2.4 3.3.0
 3.3.1
 21:54:49 /bin/sh:
 /usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f24ef85568c1c38b81b36cbceab60d298d103dab/loader/postgis:
 not found
 21:54:49 gmake[3]: *** [../upgrade-paths-rules.mk:22: install-upgrade-
 paths] Error 127
 21:54:49 gmake[3]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f24ef85568c1c38b81b36cbceab60d298d103dab/extensions/postgis'
 21:54:49 gmake[2]: *** [Makefile:29: install] Error 1
 21:54:49 gmake[2]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/f24ef85568c1c38b81b36cbceab60d298d103dab/extensions'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5246>
