[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-119-gd5033aa5e
Tue Sep 20 00:57:51 PDT 2022
the project "PostGIS".
       via  d5033aa5e19f1b8fe64b056b0a073dc352e2e3db (commit)
      from  6b60b5644c05917f09fb75894174e9bc1dc66834 (commit)
revisions in full, below.
commit d5033aa5e19f1b8fe64b056b0a073dc352e2e3db
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Sep 20 09:57:12 2022 +0200
    Run postgis from srcdir, so to not bother with exe suffix
    Should fix #5246
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 0964ea1b0..d8fb62d25 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -205,6 +205,7 @@ include $(PGXS)
 PERL = @PERL@
 srcdir = @srcdir@
+top_srcdir = @top_srcdir@
 top_builddir = @top_builddir@
 abs_topbuilddir=$(abspath $(top_builddir))
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 404fb6686..53b1026e1 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -162,5 +162,8 @@ PERL = @PERL@
 VPATH = @srcdir@
+# TODO: fix this, if srcdir is set, install of .control file fails
+#srcdir = @srcdir@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 64eec13be..1c118ccf0 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -134,5 +134,6 @@ PERL = @PERL@
 VPATH = @srcdir@
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index a1bf29b52..6acb88a6b 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -106,5 +106,6 @@ PERL = @PERL@
 VPATH = @srcdir@
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index efbc9fe30..aa291d3dc 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -217,5 +217,6 @@ PERL=@PERL@
 VPATH = @srcdir@
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index 3b4b684fc..e63f8f3d1 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -111,5 +111,6 @@ PERL=@PERL@
 VPATH = @srcdir@
diff --git a/extensions/upgrade-paths-rules.mk b/extensions/upgrade-paths-rules.mk
index 3189960fb..b2af4966d 100644
--- a/extensions/upgrade-paths-rules.mk
+++ b/extensions/upgrade-paths-rules.mk
@@ -23,7 +23,7 @@ install-upgrade-paths: tag-as-any
 	$(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
 	$(INSTALL_DATA) "sql/$(TAG_UPGRADE)" "$(EXTDIR)/$(TAG_UPGRADE)"; \
 	ln -fs "$(TAG_UPGRADE)" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--ANY.sql; \
-	$(abs_topbuilddir)/loader/postgis \
+	$(PERL) $(top_srcdir)/loader/postgis.pl \
 		install-extension-upgrades \
 		--extension $(EXTENSION) \
 		--pg_sharedir $(PG_SHAREDIR) \
Summary of changes:
 extensions/address_standardizer/Makefile.in   | 1 +
 extensions/postgis/Makefile.in                | 3 +++
 extensions/postgis_raster/Makefile.in         | 1 +
 extensions/postgis_sfcgal/Makefile.in         | 1 +
 extensions/postgis_tiger_geocoder/Makefile.in | 1 +
 extensions/postgis_topology/Makefile.in       | 1 +
 extensions/upgrade-paths-rules.mk             | 2 +-
 7 files changed, 9 insertions(+), 1 deletion(-)
hooks/post-receive
