[postgis-tickets] [PostGIS] #5246: bessies failing on upgrade
PostGIS trac at osgeo.org
Tue Sep 20 00:57:53 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"d5033aa5e19f1b8fe64b056b0a073dc352e2e3db/git" d5033aa/git]:
 {{{#!CommitTicketReference repository="git"
 revision="d5033aa5e19f1b8fe64b056b0a073dc352e2e3db"
 Run postgis from srcdir, so to not bother with exe suffix
 Should fix #5246
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5246#comment:3>
