[postgis-tickets] [PostGIS] #5249: check-no-trailing-blanks
PostGIS trac at osgeo.org
Sun Sep 25 19:08:39 PDT 2022
 Reporter:  robe    |      Owner:  robe
     Type:  defect  |     Status:  new
 Priority:  medium  |  Milestone:  PostGIS 3.4.0
Component:  sfcgal  |    Version:  master
 Keywords:          |
 21:15:21 PostGIS was built successfully. Ready to install.
 21:15:21 ! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
 21:15:21        grep -v lwin_wkt_lex.c | \
 21:15:21        grep -v lwin_wkt_parse | \
 21:15:21        grep -v lookup3 | \
 21:15:21        grep -v vector_tile.pb-c | \
 21:15:21        grep -v postgis/sqldefines.h | \
 21:15:21        grep -v deps/ | \
 21:15:21        xargs grep -n '[[:space:]]$'
 21:15:22 ./liblwgeom/lwgeom_sfcgal.c:49:        snprintf(version,
 MAX_LENGTH_SFCGAL_FULL_VERSION,
 21:15:22 ./liblwgeom/lwgeom_sfcgal.c:50:                "SFCGAL=\"%s\"
 CGAL=\"Unknown\" Boost=\"Unknown\"",
 21:15:22 make: *** [GNUmakefile:59: check-no-trailing-blanks] Error 1
 21:15:22 Build step 'Execute shell' marked build as failure
 I didn't think we changed sfcgal recently so not sure why this error
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5249>
