[postgis-tickets] [PostGIS] #5248: Missing MARC21 docs
PostGIS trac at osgeo.org
Sun Sep 25 20:00:16 PDT 2022
  Reporter:  jim            |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  low            |  Milestone:  PostGIS 3.3.2
 Component:  documentation  |    Version:  3.3.x
Resolution:                 |   Keywords:
Comment (by robe):
 @jim,
 I figured out the issue.  When I accepted your patch, I hadn't noticed you
 had it as a separate file.  I forgot to incorporate it into
 reference_input.xml and reference_output.xml files.  I'll fix in a bit.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5248#comment:2>
