[postgis-tickets] [PostGIS] #5250: Cirrus CI Freebsd failing on raster script builds
PostGIS trac at osgeo.org
Sun Sep 25 20:37:31 PDT 2022
 Reporter:  robe       |      Owner:  strk
     Type:  defect     |     Status:  assigned
 Priority:  blocker    |  Milestone:  PostGIS 3.4.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 https://github.com/postgis/postgis/runs/8541669143
 grep -v '^#' rtpostgis_legacy.sql.tmp | \
 /usr/local/bin/perl -lpe
 "s'MODULE_PATHNAME'\$libdir/postgis_raster-3'g;s'@extschema@\.''g" >
 rm rtpostgis_legacy.sql.tmp
 rm rtpostgis.sql.tmp
 rm rtpostgis_drop.sql.tmp
 /usr/local/bin/perl ../../utils/create_upgrade.pl rtpostgis.sql >
 rtpostgis_upgrade.sql.in
 /usr/local/bin/perl ../../utils/create_undef.pl rtpostgis.sql 130 >
 uninstall_rtpostgis.sql
 rm: rtpostgis_legacy.sql.tmp: No such file or directory
 gmake[3]: *** [Makefile:130: rtpostgis_legacy.sql] Error 1
 gmake[3]: *** Deleting file 'rtpostgis_legacy.sql'
 gmake[3]: *** Waiting for unfinished jobs....
 rm: rtpostgis.sql.tmp: No such file or directory
 gmake[3]: *** [Makefile:130: rtpostgis.sql] Error 1
 gmake[3]: *** Deleting file 'rtpostgis.sql'
 gmake[3]: Leaving directory '/tmp/cirrus-ci-build/raster/rt_pg'
 gmake[2]: *** [Makefile:88: ../../raster/rt_pg/uninstall_rtpostgis.sql]
 Error 2
 gmake[2]: *** Deleting file '../../raster/rt_pg/uninstall_rtpostgis.sql'
 gmake[2]: *** Waiting for unfinished jobs....
 gmake[2]: *** [Makefile:88: ../../raster/rt_pg/rtpostgis_drop.sql] Error 2
 gmake[2]: *** Deleting file '../../raster/rt_pg/rtpostgis_drop.sql'
 Unable to open input SQL file rtpostgis.sql
 gmake[3]: *** [Makefile:152: rtpostgis_upgrade.sql.in] Error 2
 gmake[3]: *** Deleting file 'rtpostgis_upgrade.sql.in'
 Couldn't open file: rtpostgis.sql
 gmake[3]: *** [Makefile:160: uninstall_rtpostgis.sql] Error 2
 ../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql] Error 2
 gmake[2]: Leaving directory '/tmp/cirrus-ci-build/extensions/postgis'
 gmake[1]: *** [Makefile:29: all] Error 1
 gmake[1]: Leaving directory '/tmp/cirrus-ci-build/extensions'
 gmake: *** [GNUmakefile:24: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5250>
