[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.3-9-gc7c59b49d
Mon Sep 26 17:29:26 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  c7c59b49d36705a68181e3cc54ccac1a3e9886b2 (commit)
      from  4161a0aac424572ebe7cb6ce32c15cff6246ba3c (commit)
revisions in full, below.
commit c7c59b49d36705a68181e3cc54ccac1a3e9886b2
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Sep 26 16:47:05 2022 -0400
    Remove a relate_bnr that results in different answer in patched GEOS.  Closes #5245 for PostGIS 3.2.4
diff --git a/regress/core/relate_bnr.sql b/regress/core/relate_bnr.sql
index 2c5d57447..4a712da14 100644
--- a/regress/core/relate_bnr.sql
+++ b/regress/core/relate_bnr.sql
@@ -28,7 +28,8 @@ SELECT '27', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as
 SELECT '28', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(0 0,60 0,60 60,60 0,120 0)'::geometry as a, 'MULTILINESTRING((0 0,60 0),(60 0,120 0),(60 0,60 60))'::geometry as b) as f;
 SELECT '29', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(140 300,220 160,260 200,240 260)'::geometry as b) as f;
 SELECT '30', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(60 40,140 40,140 160,0 160)'::geometry as b) as f;
-SELECT '31', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(140 280,240 280,240 180,140 180,140 280)'::geometry as b) as f;
+-- TODO: Put back after sometime or put in separte test file. The correct answer is in upcoming GEOS 3.9.4, 3.10.4, 3.11.1, 3.12.0
+-- SELECT '31', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(140 280,240 280,240 180,140 180,140 280)'::geometry as b) as f;
 SELECT '32', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(140 0,0 0,40 60,0 120,60 200,220 160,220 40)'::geometry as a, 'LINESTRING(80 140,180 100,160 40,100 40,60 100,80 140)'::geometry as b) as f;
 SELECT '33', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(20 20,80 80)'::geometry as a, 'LINESTRING(20 20,80 80)'::geometry as b) as f;
 SELECT '34', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(40 40,160 160,200 60,60 140)'::geometry as a, 'LINESTRING(40 40,160 160,200 60,60 140)'::geometry as b) as f;
diff --git a/regress/core/relate_bnr_expected b/regress/core/relate_bnr_expected
index 89dabee7d..6f57aeaec 100644
--- a/regress/core/relate_bnr_expected
+++ b/regress/core/relate_bnr_expected
@@ -28,7 +28,6 @@
 28|10FF0FFF2|10FF0FFF2|1FFFFFFF2|10FF0FFF2
 29|FF1FF0102|FF1FF0102|FF1FF0102|FF1FF0102
 30|FF1FF0102|FF1FF0102|FF1FFF1F2|FF1FF0102
-31|FF1FF01F2|FF1FF01F2|FF1FF01F2|FF1FF01F2
 32|FF1FF01F2|FF1FF0102|FF1FFF1F2|FF1FF01F2
 33|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
 34|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
Summary of changes:
 regress/core/relate_bnr.sql      | 3 ++-
 regress/core/relate_bnr_expected | 1 -
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
