[postgis-tickets] [PostGIS] #5245: Regression failure with relate_bnr (bogus expectance)
PostGIS trac at osgeo.org
Tue Sep 27 11:29:21 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 3.2.4
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 @strk The reason I remarked it out is the bug fix has not been released
 yet, so many of our cis will be complaining.
 Once there is a GEOS release we can put back the test.
 Or you are thinking we should keep this ticket open until we do that?  I
 honestly don't care that much about this test, so if someone sees the
 todo, maybe they'll put it back,  It's not the whole test, it's just one
 particular line item test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5245#comment:11>
