[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-140-g56f169554
Tue Sep 27 12:41:55 PDT 2022
the project "PostGIS".
       via  56f1695540c2fc98ee93e32a68e96405a0c64177 (commit)
      from  b29d0cf614ebfee3062f180dd4c587708cf0b535 (commit)
revisions in full, below.
commit 56f1695540c2fc98ee93e32a68e96405a0c64177
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Sep 27 12:41:50 2022 -0700
    Fix doc ST_Relate BNR values
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 17d2980d0..97fcc3ba3 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -1491,10 +1491,10 @@ FROM (SELECT ST_GeomFromText('POLYGON ((40 170, 90 30, 180 100, 40 170))') AS a,
                 </para></listitem>
             <listitem><para><code>2</code>: <emphasis role="bold">Endpoint</emphasis> - all endpoints are in the Boundary.
                 </para></listitem>
-            <listitem><para><code>2</code>: <emphasis role="bold">MultivalentEndpoint</emphasis> - endpoints are in the Boundary if they occur more than once.
+            <listitem><para><code>3</code>: <emphasis role="bold">MultivalentEndpoint</emphasis> - endpoints are in the Boundary if they occur more than once.
                 In other words, the boundary is all the "attached" or "inner" endpoints (but not the "unattached/outer" ones).
                 </para></listitem>
-            <listitem><para><code>2</code>: <emphasis role="bold">MonovalentEndpoint</emphasis> - endpoints are in the Boundary if they occur only once.
+            <listitem><para><code>4</code>: <emphasis role="bold">MonovalentEndpoint</emphasis> - endpoints are in the Boundary if they occur only once.
                 In other words, the boundary is all the "unattached" or "outer" endpoints.
                 </para></listitem>
         </itemizedlist>
Summary of changes:
 doc/reference_relationship.xml | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
