[postgis-tickets] [PostGIS] #5201: upgrade-path branch fails on windows
PostGIS trac at osgeo.org
Tue Sep 27 17:50:43 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 master is working fine as far as I can tell.  So if you merged already
 then this is fixed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5201#comment:8>
