[postgis-tickets] [PostGIS] #5250: Cirrus CI Freebsd failing on raster script builds
PostGIS trac at osgeo.org
Fri Sep 30 08:25:07 PDT 2022
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  assigned
  Priority:  blocker    |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by strk):
 Temptative patch (although hiding a probable issue with multi-process make
 under the carpet): https://github.com/postgis/postgis/pull/709
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5250#comment:2>
