[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-146-g03cc059dc
Fri Sep 30 09:28:24 PDT 2022
the project "PostGIS".
       via  03cc059dc01b0fa39564d97295748e6f12bfebbc (commit)
      from  e954553b5fde92b6dd1b19766db1547f6a736152 (commit)
revisions in full, below.
commit 03cc059dc01b0fa39564d97295748e6f12bfebbc
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 30 17:12:15 2022 +0200
    Do not assume .tmp file exists upon removal
    CirrusCI is failing not finding the file.
    Chances are multi-process make is building the same
    file multiple times and thus not finding it upon removing it
    A better fix would be useful (serializing those commands?)
    Should fix #5250
diff --git a/doc/Makefile.in b/doc/Makefile.in
index e6aee1809..f1d048b0c 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -188,7 +188,7 @@ $(XML_INPUTS_POT): $(srcdir)/po/templates/%.xml.pot: %.xml
       mv $@.tmp $@; \
     else \
       echo "$@ unchanged"; \
-      rm $@.tmp; \
+      rm -f $@.tmp; \
     fi; \
   else \
 	  $(XML2POT) $< > $@; \
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index d8fb62d25..653dc5b0f 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -68,7 +68,7 @@ sql/%.sql: %.sql.in | sql
 	$(SQLPP) -I at buiddir@/../libpgcommon $< > $@.tmp
 	grep -v '^#' $@.tmp | \
 	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
-	rm $@.tmp
+	rm -f $@.tmp
 %.control: %.control.in Makefile
 	cat $< \
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 53b1026e1..7b425b060 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -140,7 +140,7 @@ sql/postgis_for_extension.sql: ../../postgis/postgis.sql.in ../../postgis_revisi
 	$(PERL) -lpe \
 		"s'MODULE_PATHNAME'\$(MODULEPATH)'g" \
 		| $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' > $@
-	rm $@.tmp
+	rm -f $@.tmp
 sql/postgis_upgrade.sql: sql/postgis_upgrade_for_extension.sql | sql
 	$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 1c118ccf0..8bac04f67 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -96,7 +96,7 @@ sql/rtpostgis_for_extension.sql: ../../raster/rt_pg/rtpostgis.sql.in ../../postg
 	$(SQLPP) -I at builddir@/../../postgis/ -I../../ $< > $@.tmp
-	rm $@.tmp
+	rm -f $@.tmp
 sql/rtpostgis_upgrade.sql: sql/rtpostgis_upgrade_for_extension.sql | sql
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 60e0a486f..b5aef0768 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -239,7 +239,7 @@ endif
 %.sql: %.sql.in
 	$(SQLPP) -I at top_srcdir@/libpgcommon -I at builddir@ $< > $@.tmp
 	grep -v '^#' $@.tmp | $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
-	rm $@.tmp
+	rm -f $@.tmp
 #this is redundant but trying to fold in with extension just hangs
 postgis_upgrade.sql.in: postgis.sql ../utils/create_upgrade.pl
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index 53cc52166..cbbf6db57 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -128,7 +128,7 @@ endif
 	$(SQLPP) -I at top_builddir@/postgis/ $< > $@.tmp
-	rm $@.tmp
+	rm -f $@.tmp
 ../../liblwgeom/.libs/liblwgeom.a:
 	$(MAKE) -C ../../liblwgeom
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 93a5fcfc6..9776bb87d 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -125,7 +125,7 @@ $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
 	$(SQLPP) -I at top_builddir@/postgis $< > $@.tmp
-	rm $@.tmp
+	rm -f $@.tmp
 sfcgal_upgrade.sql.in: sfcgal.sql ../utils/create_upgrade.pl
 	$(PERL) @top_srcdir@/utils/create_upgrade.pl $< > $@
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 842de0933..cc1558b71 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -105,7 +105,7 @@ endif
-	rm $@.tmp
+	rm -f $@.tmp
 #Generate upgrade script by stripping things that can't be reinstalled
 #e.g. don't bother with tables, types, triggers, and domains
Summary of changes:
 doc/Makefile.in                             | 2 +-
 extensions/address_standardizer/Makefile.in | 2 +-
 extensions/postgis/Makefile.in              | 2 +-
 extensions/postgis_raster/Makefile.in       | 2 +-
 raster/rt_pg/Makefile.in                    | 2 +-
 sfcgal/Makefile.in                          | 2 +-
 topology/Makefile.in                        | 2 +-
 8 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
