[postgis-tickets] [PostGIS] #5250: Cirrus CI Freebsd failing on raster script builds
PostGIS trac at osgeo.org
Fri Sep 30 09:28:27 PDT 2022
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:  fixed      |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"03cc059dc01b0fa39564d97295748e6f12bfebbc/git" 03cc059/git]:
 {{{#!CommitTicketReference repository="git"
 revision="03cc059dc01b0fa39564d97295748e6f12bfebbc"
 Do not assume .tmp file exists upon removal
 CirrusCI is failing not finding the file.
 Chances are multi-process make is building the same
 file multiple times and thus not finding it upon removing it
 A better fix would be useful (serializing those commands?)
 Should fix #5250
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5250#comment:4>
