[postgis-tickets] [PostGIS] #5365: interrupt tests fail due to change in error message
PostGIS trac at osgeo.org
Fri Apr 7 15:05:40 PDT 2023
 Reporter:  strk       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.4.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 I get these failures, when not disabling interrupt tests:
  regress/core/interrupt_buffer .. failed (diff expected obtained:
 /tmp/pgis_reg/test_122_diff)
 --- /home/src/postgis/postgis/regress/core/interrupt_buffer_expected
 2023-02-18 09:11:00.360153532 +0100
 +++ /tmp/pgis_reg/test_122_out  2023-04-08 00:00:07.769328100 +0200
 @@ -1,3 +1,3 @@
 -ERROR:  canceling statement due to statement timeout
 +ERROR:  canceling statement due to user request
  buffer interrupted on time
  1|5
 And many other similar subtle changes.
 Also in regress/core/interrupt_relate and in regress/core/interrupt where
 the error message is slightly different (liblwgeom does not even try to
 loop for too long in that case now):
  regress/core/interrupt .. failed (diff expected obtained:
 /tmp/pgis_reg/test_120_diff)
 --- /home/src/postgis/postgis/regress/core/interrupt_expected   2023-02-18
 +++ /tmp/pgis_reg/test_120_out  2023-04-08 00:00:06.593328067 +0200
 @@ -1,4 +1,3 @@
 -NOTICE:  liblwgeom code interrupted
 +NOTICE:  .././../liblwgeom/ptarray.c:449 - ptarray_segmentize2d: Too many
 segments required (3.605551e+100)
  segmentize interrupted on time
  1|LINESTRING(0 0,2 0,4 0)
 I'm using the "buildbots" component becuase we don't seem to have a
 "testsuite" component (we probably should). I don't think there's any
 buildbot currently running these interrupt tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5365>
