[postgis-tickets] [PostGIS] #5366: GHA last coverage is failing on raster GDAL polygonize cUnit test
PostGIS trac at osgeo.org
Wed Apr 12 07:30:57 PDT 2023
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 3.4.0
 Component:  raster  |    Version:  master
Resolution:          |   Keywords:
Comment (by robe):
 Docker build has been failing since march (some debian apt issue, which I
 guess my patch updates and time updates fixed on April 8th).  So the issue
 upstream could have been introduced any time between March 1st and April
 11th.  At a glance not seeing anything in GDAL commit logs between such a
 period to cause this issue.
 Could also be a change in GEOS I suppose, but debbie, winnie, or berries
 should have caught those.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5366#comment:1>
