[postgis-tickets] [PostGIS] #5368: cirrus CI 12.3 failing on flatgeobuf compile
PostGIS trac at osgeo.org
Wed Apr 12 16:04:29 PDT 2023
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  master
 Keywords:           |
 https://cirrus-ci.com/task/6070532286709760
 cc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wformat-
 security -fno-strict-aliasing -fwrapv -Wno-unused-command-line-argument
 -Wno-compound-token-split-by-macro -O2 -pipe  -fstack-protector-strong
 -fno-strict-aliasing  -fPIC -DPIC -I../liblwgeom -I../liblwgeom -std=gnu99
 -isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror -fno-
 math-errno -fno-signed-zeros -Wall -I../libpgcommon -I../deps/flatgeobuf
 -I../deps/wagyu -I../deps/uthash/include  -I/usr/local/include
 -I/usr/local/include  -I/usr/local/include  -I/usr/local/include/libxml2
 -I/usr/local/include -I/usr/local/include -I/usr/local/include/json-c
 -I/usr/local/include  -DNDEBUG   -fPIC -DPIC -I. -I./
 -I/usr/local/include/postgresql/server
 -I/usr/local/include/postgresql/internal  -I/usr/local/include
 -I/usr/local/include -I/usr/local/include  -c -o postgis_module.o
 postgis_module.c
 error: unknown warning option '-Wno-compound-token-split-by-macro'
 [-Werror,-Wunknown-warning-option]
 13.1 run is fine though
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5368>
