[postgis-tickets] [PostGIS] #5369: GetTopoGeomElements documentation does not mention the return is about primitives
PostGIS trac at osgeo.org
Thu Apr 13 08:59:17 PDT 2023
primitives
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.0.9
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by robe):
 I noticed it is clearly documented already.  What change did you have in
 mind?
 It says:
 Returns a set of topoelemnt objects containing the topological
 element_id,element_type of the given TopoGeometry (**primitive
 elements**).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5369#comment:3>
