[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-728-gb98da54ef
Thu Apr 13 20:08:29 PDT 2023
the project "PostGIS".
       via  b98da54ef790dd23aff70cc454b476a7934a7726 (commit)
       via  c58a442120fb1ae35ae6283e47e38090d8f8d1a3 (commit)
       via  e5f5ededc11f6e8f3c1de91bb1b51e6241721c30 (commit)
       via  b7ffe00eef042a4e65caab25dbbdfc2450f9bd40 (commit)
       via  9c3a6b3a3ddd168bafae6ff80cd12809ad1ee473 (commit)
       via  6923ea003bca45cd8dbee9602a99d1f5b25f5921 (commit)
       via  6dd2fc18cbbab176f710142348b62764f197f962 (commit)
       via  661b9a8748a5e0862412d5f5ba23a0b13e694a3c (commit)
       via  54ed9796c462b3af3f963c437c8b2593e7a60c06 (commit)
       via  b2f871319d771e31320bf4212787f62ce49854d7 (commit)
       via  a2d89501ba91d484d26abfb9012f6df0c1efd536 (commit)
       via  9adc34a1720f697d71fa2dd6a49202add8a4ef28 (commit)
       via  8f4d7bafa179e1dbee61faf17918c73ea4f7d87a (commit)
       via  a598157bf5f215bd1416d143185d07f11dd84a32 (commit)
       via  f288377222ed4fbddaeae5211f7c68cc97ac26a3 (commit)
      from  255aa0ffdb2d96801a06c1e5bf38ca5bc8310208 (commit)
revisions in full, below.
commit b98da54ef790dd23aff70cc454b476a7934a7726
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Thu Apr 13 02:19:44 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (26 of 26 strings)
    Translation: postgis/reference_exception.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_exceptionxml/ja/
diff --git a/doc/po/ja/reference_exception.xml.po b/doc/po/ja/reference_exception.xml.po
index 74a1ecf73..de9404bd3 100644
--- a/doc/po/ja/reference_exception.xml.po
+++ b/doc/po/ja/reference_exception.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2022-10-25 07:30+0000\n"
+"PO-Revision-Date: 2023-04-14 03:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "reference_exceptionxml/ja/>\n"
@@ -15,7 +15,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.14.1\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: title
 #: reference_exception.xml:3
commit c58a442120fb1ae35ae6283e47e38090d8f8d1a3
Date:   Thu Apr 13 02:20:42 2023 +0000
    Currently translated at 100.0% (69 of 69 strings)
    Translation: postgis/reference_cluster.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_clusterxml/ja/
diff --git a/doc/po/ja/reference_cluster.xml.po b/doc/po/ja/reference_cluster.xml.po
index f436a6288..fa230a8b7 100644
--- a/doc/po/ja/reference_cluster.xml.po
+++ b/doc/po/ja/reference_cluster.xml.po
 "Project-Id-Version: PACKAGE VERSION\n"
 "POT-Creation-Date: 2023-04-10 06:16+0000\n"
-"PO-Revision-Date: 2023-04-12 10:08+0000\n"
 "reference_clusterxml/ja/>\n"
@@ -160,7 +160,7 @@ msgstr "Availability: 2.3.0"
 #: reference_cluster.xml:73 reference_cluster.xml:330 reference_cluster.xml:374
 #, no-c-format
 msgid "&curve_support;"
-msgstr ""
+msgstr "&curve_support;"
 #. Tag: title
 #: reference_cluster.xml:77 reference_cluster.xml:147 reference_cluster.xml:188
@@ -306,12 +306,15 @@ msgid ""
 "linkend=\"ST_ClusterIntersecting\"/>, <xref linkend=\"ST_ClusterWithin\"/> "
 "<xref linkend=\"ST_ClusterIntersectingWin\"/>"
 msgstr ""
+", <xref linkend=\"ST_ClusterKMeans\"/>, <xref linkend="
+"\"ST_ClusterIntersecting\"/>, <xref linkend=\"ST_ClusterWithin\"/> <xref "
+"linkend=\"ST_ClusterIntersectingWin\"/>"
 #. Tag: refname
 #: reference_cluster.xml:124
 #, no-c-format
 msgid "ST_ClusterIntersectingWin"
-msgstr ""
+msgstr "ST_ClusterIntersectingWin"
 #. Tag: refpurpose
 #: reference_cluster.xml:126
@@ -319,7 +322,8 @@ msgstr ""
 msgid ""
 "Window function that returns a cluster id for each input geometry, "
 "clustering input geometries into connected sets."
-msgstr ""
+msgstr "入力ジオメトリごとに接続された集合にクラスタリングを行い、クラスタIDを返すウ"
+"ィンドウ関数です。"
 #. Tag: funcprototype
 #: reference_cluster.xml:131
@@ -329,6 +333,9 @@ msgid ""
 "<paramdef><type>geometry winset </type> <parameter>geom</parameter></"
 "paramdef>"
 msgstr ""
+"<funcdef>integer <function>ST_ClusterIntersectingWin</function></funcdef> "
+"<paramdef><type>geometry winset </type> "
+"<parameter>geom</parameter></paramdef>"
 #. Tag: para
 #: reference_cluster.xml:141
@@ -340,6 +347,10 @@ msgid ""
 "the cluster number that the geometry argument participates in, or null for "
 "null inputs."
 msgstr ""
+"ST_ClusterIntersectingWinは、インタセクトするジオメトリの相互接続するクラスタ"
+"を構築するウィンドウ関数です。クラスタを出ることなく全てのジオメトリを横断す"
+"ることができます。返り値は引数のジオメトリが関係するクラスタ番号か、入力がNUL"
+"Lの場合にはNULLかのいずれかです。"
 #. Tag: para
 #: reference_cluster.xml:143 reference_cluster.xml:373
@@ -372,6 +383,26 @@ msgid ""
 "  4 | LINESTRING(0 0,-1 -1)          |       0\n"
 "  5 | POLYGON((0 0,4 0,4 4,0 4,0 0)) |       0"
 msgstr ""
+"WITH testdata AS (\n"
+"  SELECT id, geom::geometry FROM (\n"
+"  VALUES  (1, 'LINESTRING (0 0, 1 1)'),\n"
+"          (2, 'LINESTRING (5 5, 4 4)'),\n"
+"          (3, 'LINESTRING (6 6, 7 7)'),\n"
+"          (4, 'LINESTRING (0 0, -1 -1)'),\n"
+"          (5, 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))')) AS t(id, geom)\n"
+")\n"
+"SELECT id, \n"
+"  ST_AsText(geom), \n"
+"  ST_ClusterIntersectingWin(geom) OVER () AS cluster \n"
+"FROM testdata;\n"
+"\n"
+" id |           st_astext            | cluster \n"
+"----+--------------------------------+---------\n"
+"  1 | LINESTRING(0 0,1 1)            |       0\n"
+"  2 | LINESTRING(5 5,4 4)            |       0\n"
+"  3 | LINESTRING(6 6,7 7)            |       1\n"
+"  4 | LINESTRING(0 0,-1 -1)          |       0\n"
+"  5 | POLYGON((0 0,4 0,4 4,0 4,0 0)) |       0"
 #. Tag: para
 #: reference_cluster.xml:152
@@ -381,6 +412,9 @@ msgid ""
 "linkend=\"ST_ClusterWithinWin\"/> <xref linkend=\"ST_ClusterWithin\"/> <xref "
 "linkend=\"ST_ClusterIntersecting\"/>"
 msgstr ""
+", <xref linkend=\"ST_ClusterKMeans\"/>, <xref linkend=\"ST_ClusterWithinWin\""
+"/> <xref linkend=\"ST_ClusterWithin\"/> <xref linkend="
+"\"ST_ClusterIntersecting\"/>"
 #. Tag: refname
 #: reference_cluster.xml:165
@@ -392,7 +426,7 @@ msgstr "ST_ClusterIntersecting"
 #: reference_cluster.xml:167
 #, no-c-format
 msgid "Aggregate function that clusters input geometries into connected sets."
-msgstr ""
+msgstr "入力ジオメトリを接続関係にある集合にクラスタリングする集約関数です。"
 #: reference_cluster.xml:172
@@ -442,6 +476,22 @@ msgid ""
 "-1),POLYGON((0 0,4 0,4 4,0 4,0 0)))\n"
 "GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))"
 msgstr ""
+"WITH testdata AS\n"
+"  (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,\n"
+"           'LINESTRING (5 5, 4 4)'::geometry,\n"
+"           'LINESTRING (6 6, 7 7)'::geometry,\n"
+"           'LINESTRING (0 0, -1 -1)'::geometry,\n"
+"           'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)\n"
+"\n"
+"SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;\n"
+"\n"
+"-- 結果 --\n"
+"\n"
+"st_astext\n"
+"---------\n"
+"GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 "
+"-1),POLYGON((0 0,4 0,4 4,0 4,0 0)))\n"
+"GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))"
 #. Tag: para
 #: reference_cluster.xml:193
@@ -450,6 +500,8 @@ msgid ""
 ", <xref linkend=\"ST_ClusterKMeans\"/>, <xref "
 "linkend=\"ST_ClusterWithinWin\"/> <xref linkend=\"ST_ClusterWithin\"/>"
 msgstr ""
+"/> <xref linkend=\"ST_ClusterWithin\"/>"
 #. Tag: refname
 #: reference_cluster.xml:211
@@ -709,6 +761,10 @@ msgid ""
 ">, <xref linkend=\"ST_ClusterWithin\"/>, <xref linkend=\"ST_Subdivide\"/>, "
 "<xref linkend=\"ST_Force_3D\"/>, <xref linkend=\"ST_Force_4D\"/>,"
 msgstr ""
+", <xref linkend=\"ST_ClusterIntersectingWin\"/>, <xref linkend="
+"\"ST_ClusterWithinWin\"/>, <xref linkend=\"ST_ClusterIntersecting\"/>, <xref "
+"linkend=\"ST_ClusterWithin\"/>, <xref linkend=\"ST_Subdivide\"/>, <xref "
+"linkend=\"ST_Force_3D\"/>, <xref linkend=\"ST_Force_4D\"/>,"
 #. Tag: refname
 #: reference_cluster.xml:309
@@ -721,7 +777,7 @@ msgstr "ST_ClusterWithin"
 #, no-c-format
 msgid ""
 "Aggregate function that clusters input geometries by separation distance."
-msgstr ""
+msgstr "空間的な距離によって入力ジオメトリのクラスタリングを行う集約関数です。"
 #: reference_cluster.xml:316
@@ -796,12 +852,15 @@ msgid ""
 "linkend=\"ST_ClusterIntersectingWin\"/>, <xref "
 "linkend=\"ST_ClusterWithinWin\"/>, <xref linkend=\"ST_ClusterIntersecting\"/>"
 msgstr ""
+"\"ST_ClusterIntersectingWin\"/>, <xref linkend=\"ST_ClusterWithinWin\"/>, "
+"<xref linkend=\"ST_ClusterIntersecting\"/>"
 #. Tag: refname
 #: reference_cluster.xml:352
 #, no-c-format
 msgid "ST_ClusterWithinWin"
-msgstr ""
+msgstr "ST_ClusterWithinWin"
 #. Tag: refpurpose
 #: reference_cluster.xml:354
@@ -809,7 +868,8 @@ msgstr ""
 msgid ""
 "clustering using separation distance."
-msgstr ""
+msgstr "入力ジオメトリごとに分離距離を使ったクラスタリングを行い、クラスタIDを返すウ"
+"ィンドウ関数です。"
 #: reference_cluster.xml:359
@@ -820,6 +880,10 @@ msgid ""
 "paramdef> <paramdef><type>float8 </type> <parameter>distance</parameter></"
 "paramdef>"
 msgstr ""
+"<funcdef>integer <function>ST_ClusterWithinWin</function></funcdef> "
+"<paramdef><type>geometry winset </type> <parameter>geom</parameter></"
+"paramdef> <paramdef><type>float8 </type> "
+"<parameter>distance</parameter></paramdef>"
 #. Tag: para
 #: reference_cluster.xml:370
@@ -831,6 +895,10 @@ msgid ""
 "than the specified distance. (Distances are Cartesian distances in the units "
 "of the SRID.)"
 msgstr ""
+"ST_ClusterWithinWinは、ジオメトリ毎に整数を返すウィンドウ関数です。この整数は"
+"、ジオメトリがメンバになっているクラスタの番号です。"
+"クラスタは指定距離以上でない入力ジオメトリの集合を表現します "
+"(距離はSRIDの単位のデカルト距離です。)"
 #. Tag: para
 #: reference_cluster.xml:372
@@ -839,6 +907,8 @@ msgid ""
 "ST_ClusterWithinWin is equivalent to running <xref "
 "linkend=\"ST_ClusterDBSCAN\"/> with a `minpoints` of zero."
 msgstr ""
+"ST_ClusterWithinWinは<xref linkend=\"ST_ClusterDBSCAN\""
+"/>を、`minpoints`を0にして実行するのと同じです。"
 #. Tag: programlisting
 #: reference_cluster.xml:380
@@ -866,6 +936,27 @@ msgid ""
 msgstr ""
+")\n"
+"SELECT id, \n"
+"  ST_ClusterWithinWin(geom, 1.4) OVER () AS cluster \n"
+"FROM testdata;\n"
+"\n"
+"\n"
 #. Tag: para
 #: reference_cluster.xml:384
@@ -875,6 +966,9 @@ msgid ""
 "linkend=\"ST_ClusterIntersectingWin\"/>, <xref linkend=\"ST_ClusterWithin\"/"
 ">, <xref linkend=\"ST_ClusterIntersecting\"/>"
 msgstr ""
+"\"ST_ClusterIntersectingWin\"/>, <xref linkend=\"ST_ClusterWithin\"/>, <xref "
+"linkend=\"ST_ClusterIntersecting\"/>"
 #, no-c-format
 #~ msgid ""
commit e5f5ededc11f6e8f3c1de91bb1b51e6241721c30
Date:   Thu Apr 13 01:54:53 2023 +0000
    Currently translated at 100.0% (297 of 297 strings)
    Translation: postgis/reference_editor.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_editorxml/ja/
diff --git a/doc/po/ja/reference_editor.xml.po b/doc/po/ja/reference_editor.xml.po
index f97c52eaf..ad2b370c7 100644
--- a/doc/po/ja/reference_editor.xml.po
+++ b/doc/po/ja/reference_editor.xml.po
@@ -4,13 +4,13 @@
 # TERAMOTO Ikuhiro <yellow at affrc.go.jp>, 2016
 # Sandro Santilli <strk at kbt.io>, 2022.
 # Regina Obe <regina at arrival3d.com>, 2022.
-# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022.
+# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022, 2023.
 msgid ""
 msgstr ""
 "reference_editorxml/ja/>\n"
@@ -19,7 +19,7 @@ msgstr ""
 #. Tag: para
 #: reference_editor.xml:5
@@ -2847,7 +2847,8 @@ msgstr "ST_Segmentize"
 msgid ""
 "Returns a modified geometry/geography having no segment longer than a given "
 "distance."
-msgstr ""
+msgstr "与えた長さを超える線分を持たないよう変更したジオメトリ/ジオグラフィを返します"
 #. Tag: funcsynopsis
 #: reference_editor.xml:1275
@@ -2877,6 +2878,9 @@ msgid ""
 "<varname>max_segment_length</varname>. Length is computed in 2D. Segments "
 "are always split into equal-length subsegments."
 msgstr ""
+"<varname>max_segment_length</varname>を超える長さの線分を持たないよう変更した"
+"ジオメトリ/ジオグラフィを返します。長さは2次元で計算されます。線分は常に等長"
+"の線分に分割されます。"
 #. Tag: para
 #: reference_editor.xml:1298
@@ -2884,7 +2888,7 @@ msgstr ""
 msgid ""
 "For geometry, the maximum length is in the units of the spatial reference "
 "system."
-msgstr ""
+msgstr "ジオメトリについては、最大長の単位は空間参照系の単位です。"
 #. Tag: para
 #: reference_editor.xml:1301
@@ -2894,6 +2898,8 @@ msgid ""
 "the sphere. Added vertices are created along the spherical great-circle arcs "
 "defined by segment endpoints."
 msgstr ""
+"ジオグラフィについては、最大長の単位はメートルです。距離は球面で計算します。"
+"追加される頂点は、線分の端点間で定まる球面の大円弧に沿うように作られます。"
 #. Tag: para
 #: reference_editor.xml:1308
@@ -2901,7 +2907,8 @@ msgstr ""
 msgid ""
 "This only shortens long segments. It does not lengthen segments shorter than "
 "the maximum length."
-msgstr ""
+msgstr "この関数は長い線分を短くするだけです。最大長より短い線分を長くすることはしま"
+"せん。"
 #. Tag: para
 #: reference_editor.xml:1312
@@ -2912,6 +2919,10 @@ msgid ""
 "vertices to be added. This can happen unintentionally if the argument is "
 "specified accidentally as a number of segments, rather than a maximum length."
 msgstr ""
+"長い線分を含む入力では、比較的短い <varname>max_segment_length</varname> を指"
+"定すると、非常に多くの頂点が追加される可能性があります。これは、引数が最大長"
+"ではなく線分数として誤って指定された場合に、意図せずに発生する可能性がありま"
+"す。"
 #. Tag: para
 #: reference_editor.xml:1319
@@ -2924,14 +2935,14 @@ msgstr "Availability: 1.2.2"
 #, no-c-format
 msgid ""
 "Enhanced: 3.0.0 Segmentize geometry now produces equal-length subsegments"
-msgstr ""
+msgstr "Enhanced: 3.0.0 ジオメトリの分割において、現在は、同じ長さに分割しています"
 #. Tag: para
 #: reference_editor.xml:1321
 #, no-c-format
 msgid ""
 "Enhanced: 2.3.0 Segmentize geography now produces equal-length subsegments"
-msgstr ""
+msgstr "Enhanced: 2.3.0 ジオグラフィの分割において、現在は、同じ長さに分割しています"
 #. Tag: para
 #: reference_editor.xml:1322
@@ -2950,6 +2961,11 @@ msgid ""
 "type (e.g. <code>ST_Segmentize('LINESTRING(1 2, 3 4)'::geometry, 0.5) )</"
 "code>"
 msgstr ""
+"Changed: 2.1.0 ジオグラフィ対応の導入の結果、<code>ST_Segmentize('LINESTRING("
+"1 2, 3 4)', 0.5)</code>とすると、あいまい関数エラーが発生します。入力ではジオ"
+"メトリかジオグラフィかを確実に指定する必要があります。ST_GeomFromText、ST_Geo"
+"gFromText、使いたい型へのキャスト (例: <code>ST_Segmentize('LINESTRING(1 2, "
+"3 4)'::geometry, 0.5) )</code>を行います"
 #. Tag: para
 #: reference_editor.xml:1333
@@ -2957,7 +2973,7 @@ msgstr ""
 msgid ""
 "Segmentizing a line. Long segments are split evenly, and short segments are "
 "not split."
-msgstr ""
+msgstr "ラインの分割。長い線分は均等に分割され、短い線分は分割されません。"
 #: reference_editor.xml:1334
@@ -2969,12 +2985,17 @@ msgid ""
 "---------------------------------------------------\n"
 "MULTILINESTRING((0 0,0 1,0 5,0 9),(1 10,1 14,1 18))"
 msgstr ""
+"SELECT ST_AsText(ST_Segmentize(\n"
+"    'MULTILINESTRING((0 0, 0 1, 0 9),(1 10, 1 18))'::geometry,\n"
+"        5 ) );\n"
+"---------------------------------------------------\n"
+"MULTILINESTRING((0 0,0 1,0 5,0 9),(1 10,1 14,1 18))"
 #. Tag: para
 #: reference_editor.xml:1336
 #, no-c-format
 msgid "Segmentizing a polygon:"
-msgstr ""
+msgstr "ポリゴンの分割:"
 #: reference_editor.xml:1337
@@ -2985,6 +3006,10 @@ msgid ""
 "-------------------------------------------------------\n"
 "POLYGON((0 0,0 8,7.5 6,15 4,22.5 2,30 0,20 0,10 0,0 0))"
 msgstr ""
+"SELECT ST_AsText(\n"
+"        ST_Segmentize(('POLYGON((0 0, 0 8, 30 0, 0 0))'::geometry), 10));\n"
+"-------------------------------------------------------\n"
+"POLYGON((0 0,0 8,7.5 6,15 4,22.5 2,30 0,20 0,10 0,0 0))"
 #. Tag: para
 #: reference_editor.xml:1339
@@ -2993,7 +3018,8 @@ msgid ""
 "Segmentizing a geographic line, using a maximum segment length of 2000 "
 "kilometers. Vertices are added along the great-circle arc connecting the "
 "endpoints."
-msgstr ""
+msgstr "2000キロメートルの最大線分長を使ったジオグラフィのラインの分割。頂点は、端点"
+"間をつなぐ大円弧に沿って追加されます。"
 #: reference_editor.xml:1342
@@ -3007,12 +3033,19 @@ msgid ""
 "33.21091076089908,25.779290201459894 41.01711439406505,34.188839517966954 "
 "48.337222885886,45.238153936612264 54.84733442373889,60 60)"
 msgstr ""
+"        ST_Segmentize(('LINESTRING (0 0, 60 60)'::geography), 2000000));\n"
+"-------------------------------------------------------------\n"
+"LINESTRING(0 0,4.252632294621186 8.43596525986862,8.69579947419404 "
+"16.824093489701564,13.550465473227048 25.107950473646188,19.1066053508691 "
+"33.21091076089908,25.779290201459894 41.01711439406505,34.188839517966954 "
+"48.337222885886,45.238153936612264 54.84733442373889,60 60)"
 #. Tag: para
 #: reference_editor.xml:1348
 #, no-c-format
 msgid "A geographic line segmentized along a great circle arc"
-msgstr ""
+msgstr "大円弧に沿って細分化されたジオグラフィのライン"
 #. Tag: refname
 #: reference_editor.xml:1361
commit b7ffe00eef042a4e65caab25dbbdfc2450f9bd40
    Currently translated at 100.0% (117 of 117 strings)
    Translation: postgis/reference_bbox.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_bboxxml/ja/
diff --git a/doc/po/ja/reference_bbox.xml.po b/doc/po/ja/reference_bbox.xml.po
index 99ded4bdf..6c0289dfa 100644
--- a/doc/po/ja/reference_bbox.xml.po
+++ b/doc/po/ja/reference_bbox.xml.po
 "POT-Creation-Date: 2022-04-16 08:20+0000\n"
-"PO-Revision-Date: 2023-02-14 02:23+0000\n"
 "reference_bboxxml/ja/>\n"
-"X-Generator: Weblate 4.15.2\n"
 #. Tag: para
 #: reference_bbox.xml:5
commit 9c3a6b3a3ddd168bafae6ff80cd12809ad1ee473
    Currently translated at 100.0% (80 of 80 strings)
    Translation: postgis/reference_srs.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_srsxml/ja/
diff --git a/doc/po/ja/reference_srs.xml.po b/doc/po/ja/reference_srs.xml.po
index 7bc5d1806..a5a2902a1 100644
--- a/doc/po/ja/reference_srs.xml.po
+++ b/doc/po/ja/reference_srs.xml.po
 "POT-Creation-Date: 2022-11-01 14:51+0000\n"
-"PO-Revision-Date: 2022-11-15 04:30+0000\n"
 "reference_srsxml/ja/>\n"
 #. Tag: para
 #: reference_srs.xml:5
commit 6923ea003bca45cd8dbee9602a99d1f5b25f5921
    Translation: postgis/reference_troubleshooting.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_troubleshootingxml/ja/
diff --git a/doc/po/ja/reference_troubleshooting.xml.po b/doc/po/ja/reference_troubleshooting.xml.po
index 54540189a..40a122a0d 100644
--- a/doc/po/ja/reference_troubleshooting.xml.po
+++ b/doc/po/ja/reference_troubleshooting.xml.po
 "reference_troubleshootingxml/ja/>\n"
 #. Tag: para
 #: reference_troubleshooting.xml:5
commit 6dd2fc18cbbab176f710142348b62764f197f962
    Currently translated at 100.0% (328 of 328 strings)
    Translation: postgis/reference_output.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_outputxml/ja/
diff --git a/doc/po/ja/reference_output.xml.po b/doc/po/ja/reference_output.xml.po
index 00784ccdd..213eacc7b 100644
--- a/doc/po/ja/reference_output.xml.po
+++ b/doc/po/ja/reference_output.xml.po
 "POT-Creation-Date: 2022-11-27 05:42+0000\n"
-"PO-Revision-Date: 2022-12-14 07:30+0000\n"
 "reference_outputxml/ja/>\n"
 #. Tag: para
 #: reference_output.xml:6
commit 661b9a8748a5e0862412d5f5ba23a0b13e694a3c
    Currently translated at 100.0% (291 of 291 strings)
    Translation: postgis/reference_input.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_inputxml/ja/
diff --git a/doc/po/ja/reference_input.xml.po b/doc/po/ja/reference_input.xml.po
index b16124a14..f233b6e4c 100644
--- a/doc/po/ja/reference_input.xml.po
+++ b/doc/po/ja/reference_input.xml.po
@@ -10,7 +10,7 @@ msgstr ""
 "POT-Creation-Date: 2023-02-10 06:01+0000\n"
 "reference_inputxml/ja/>\n"
 #. Tag: para
 #: reference_input.xml:6
commit 54ed9796c462b3af3f963c437c8b2593e7a60c06
    Currently translated at 100.0% (400 of 400 strings)
    Translation: postgis/reference_accessor.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_accessorxml/ja/
diff --git a/doc/po/ja/reference_accessor.xml.po b/doc/po/ja/reference_accessor.xml.po
index 08e3ab707..bf19fb0c5 100644
--- a/doc/po/ja/reference_accessor.xml.po
+++ b/doc/po/ja/reference_accessor.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "POT-Creation-Date: 2022-07-14 02:04+0000\n"
 "reference_accessorxml/ja/>\n"
@@ -16,7 +16,7 @@ msgstr ""
 #. Tag: title
 #: reference_accessor.xml:4
commit b2f871319d771e31320bf4212787f62ce49854d7
    Currently translated at 100.0% (224 of 224 strings)
    Translation: postgis/reference_operator.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_operatorxml/ja/
diff --git a/doc/po/ja/reference_operator.xml.po b/doc/po/ja/reference_operator.xml.po
index cc745e0a9..b5188d22d 100644
--- a/doc/po/ja/reference_operator.xml.po
+++ b/doc/po/ja/reference_operator.xml.po
 "reference_operatorxml/ja/>\n"
 #. Tag: title
 #: reference_operator.xml:3
commit a2d89501ba91d484d26abfb9012f6df0c1efd536
    Currently translated at 100.0% (86 of 86 strings)
    Translation: postgis/reference_transformation.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_transformationxml/ja/
diff --git a/doc/po/ja/reference_transformation.xml.po b/doc/po/ja/reference_transformation.xml.po
index 2f8dd7201..c7cb0caf0 100644
--- a/doc/po/ja/reference_transformation.xml.po
+++ b/doc/po/ja/reference_transformation.xml.po
 "reference_transformationxml/ja/>\n"
 #. Tag: para
 #: reference_transformation.xml:5
commit 9adc34a1720f697d71fa2dd6a49202add8a4ef28
    Currently translated at 100.0% (304 of 304 strings)
    Translation: postgis/reference_relationship.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_relationshipxml/ja/
diff --git a/doc/po/ja/reference_relationship.xml.po b/doc/po/ja/reference_relationship.xml.po
index 6b452e991..48c0c0de1 100644
--- a/doc/po/ja/reference_relationship.xml.po
+++ b/doc/po/ja/reference_relationship.xml.po
@@ -11,7 +11,7 @@ msgstr ""
 "reference_relationshipxml/ja/>\n"
commit 8f4d7bafa179e1dbee61faf17918c73ea4f7d87a
    Currently translated at 100.0% (315 of 315 strings)
    Translation: postgis/reference_measure.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_measurexml/ja/
diff --git a/doc/po/ja/reference_measure.xml.po b/doc/po/ja/reference_measure.xml.po
index f2aaf8903..4b6ad604f 100644
--- a/doc/po/ja/reference_measure.xml.po
+++ b/doc/po/ja/reference_measure.xml.po
@@ -8,7 +8,7 @@ msgstr ""
 "reference_measurexml/ja/>\n"
commit a598157bf5f215bd1416d143185d07f11dd84a32
    Currently translated at 100.0% (66 of 66 strings)
    Translation: postgis/reference_management.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_managementxml/ja/
diff --git a/doc/po/ja/reference_management.xml.po b/doc/po/ja/reference_management.xml.po
index ad6edcb29..72dd4786c 100644
--- a/doc/po/ja/reference_management.xml.po
+++ b/doc/po/ja/reference_management.xml.po
 "reference_managementxml/ja/>\n"
 #. Tag: para
 #: reference_management.xml:5
commit f288377222ed4fbddaeae5211f7c68cc97ac26a3
    Currently translated at 100.0% (255 of 255 strings)
    Translation: postgis/reference_constructor.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_constructorxml/ja/
diff --git a/doc/po/ja/reference_constructor.xml.po b/doc/po/ja/reference_constructor.xml.po
index 6e3599ff5..efcc3699f 100644
--- a/doc/po/ja/reference_constructor.xml.po
+++ b/doc/po/ja/reference_constructor.xml.po
 "POT-Creation-Date: 2022-08-27 04:57+0000\n"
 "reference_constructorxml/ja/>\n"
 #. Tag: title
 #: reference_constructor.xml:3
Summary of changes:
 doc/po/ja/reference_accessor.xml.po        |   4 +-
 doc/po/ja/reference_bbox.xml.po            |   4 +-
 doc/po/ja/reference_cluster.xml.po         | 110 ++++++++++++++++++++++++++---
 doc/po/ja/reference_constructor.xml.po     |   4 +-
 doc/po/ja/reference_editor.xml.po          |  57 +++++++++++----
 doc/po/ja/reference_exception.xml.po       |   4 +-
 doc/po/ja/reference_input.xml.po           |   4 +-
 doc/po/ja/reference_management.xml.po      |   4 +-
 doc/po/ja/reference_measure.xml.po         |   2 +-
 doc/po/ja/reference_operator.xml.po        |   4 +-
 doc/po/ja/reference_output.xml.po          |   4 +-
 doc/po/ja/reference_relationship.xml.po    |   2 +-
 doc/po/ja/reference_srs.xml.po             |   4 +-
 doc/po/ja/reference_transformation.xml.po  |   4 +-
 doc/po/ja/reference_troubleshooting.xml.po |   4 +-
 15 files changed, 171 insertions(+), 44 deletions(-)
hooks/post-receive
