[postgis-tickets] [PostGIS] #5370: bessie regress failures on raster after upgrade to GDAL 3.6.1 and Proj 9.2.0
PostGIS trac at osgeo.org
Fri Apr 14 18:21:50 PDT 2023
9.2.0
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.4.0
Component:  buildbots  |    Version:  3.3.x
 Keywords:             |
 To get around #5368, I took off the cirrus FreeBSD 12.3 testing and
 upgraded bessie so she's testing more or less same versions of things.
 Though cirrus was never testing raster.  I think we had disabled raster
 testing on cirrus a while ago cause it was giving mysterious errors.
 But anyway after the upgrade surgery, bessie is in tears
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/4437/label=bessie/console
  with these errors which might just be a postgres account issue that
 somehow the context changed and the account running under doesn't have
 rights to ENABLE_ALL / DISABLE_ALL anymore
 20:32:28  raster/test/regress/check_gdal .. failed (diff expected
 obtained:
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_230_diff)
 20:32:28
 20:32:28 --- ./raster/test/regress/check_gdal_expected  2023-04-14
 20:25:42.515822000 -0400
 20:32:28 +++
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_230_out
 2023-04-14 20:32:28.456935000 -0400
 20:32:28 @@ -3,7 +3,9 @@
 20:32:28  DISABLE_ALL
 20:32:28  ENABLE_ALL
 20:32:28  t
 20:32:28 +WARNING:  Unknown GDAL driver: PNG
 20:32:28 +WARNING:  Unknown GDAL driver: JPEG
 20:32:28  GTiff PNG JPEG
 20:32:28 -t
 20:32:28 +f
 20:32:28  t
 20:32:28
 20:32:49  raster/test/regress/rt_fromgdalraster .. failed (diff expected
 obtained:
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_275_diff)
 20:32:49
 20:32:49 --- ./raster/test/regress/rt_fromgdalraster_expected   2023-04-14
 20:25:42.529874000 -0400
 20:32:49 +++
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_275_out
 2023-04-14 20:32:49.627946000 -0400
 20:32:49 @@ -1,3 +1,4 @@
 20:32:49
 -(0,0,90,90,1,-1,0,0,0,3)|(8100,1479000,182.592592592593,114.982851945091,0,255)|(8100,1479000,182.592592592593,114.982851945091,0,255)|(8100,1453500,179.444444444444,116.438931167192,0,255)
 20:32:49 +WARNING:  Unknown GDAL driver: PNG
 20:32:49 +ERROR:  RASTER_fromGDALRaster: Could not open bytea with GDAL.
 Check that the bytea is of a GDAL supported format
 20:32:49
 1|(-168,85,10,10,0.083,-0.083,0,0,4269,3)|(100,0,0,0,0,0)|(100,0,0,0,0,0)|(100,0,0,0,0,0)
 20:32:49
 2|(-168,85,10,10,0.083,-0.083,0,0,4326,3)|(100,0,0,0,0,0)|(100,0,0,0,0,0)|(100,0,0,0,0,0)
 20:32:49
 20:32:49  raster/test/regress/rt_asgdalraster .. failed (diff expected
 obtained:
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_276_diff)
 20:32:50
 20:32:50 --- ./raster/test/regress/rt_asgdalraster_expected     2023-04-14
 20:25:42.525932000 -0400
 20:32:50 +++
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_276_out
 2023-04-14 20:32:49.988208000 -0400
 20:32:50 @@ -1,16 +1,18 @@
 20:32:50 +WARNING:  Unknown GDAL driver: PNG at character 49
 20:32:50 +WARNING:  Unknown GDAL driver: JPEG at character 49
 20:32:50  0
 20:32:50  1
 20:32:50  1
 20:32:50  1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50 +ERROR:  rt_raster_to_gdal: Could not load the output GDAL driver
 20:32:50
 20:32:50  raster/test/regress/rt_astiff .. ok in 384 ms
 20:32:50  raster/test/regress/rt_asjpeg .. failed (diff expected obtained:
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_278_diff)
 20:32:50
 20:32:50 --- ./raster/test/regress/rt_asjpeg_expected   2023-04-14
 20:25:42.526029000 -0400
 20:32:50 +++
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_278_out
 2023-04-14 20:32:50.753779000 -0400
 20:32:50 @@ -1,10 +1,11 @@
 20:32:50 +WARNING:  Unknown GDAL driver: JPEG at character 18
 20:32:50  t
 20:32:50  ERROR:  The pixel type of band 1 in the raster is not 8BUI.  The
 JPEG format can only be used with the 8BUI pixel type.
 20:32:50 -1
 20:32:50 -1
 20:32:50 -1
 20:32:50  NOTICE:  The JPEG format only permits one or three bands.  The
 first band will be used.
 20:32:50 -1
 20:32:50
 20:32:50  raster/test/regress/rt_aspng .. failed (diff expected obtained:
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_279_diff)
 20:32:51
 20:32:51 --- ./raster/test/regress/rt_aspng_expected    2023-04-14
 20:25:42.526326000 -0400
 20:32:51 +++
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_279_out
 2023-04-14 20:32:51.109555000 -0400
 20:32:51 @@ -1,11 +1,12 @@
 20:32:51 +WARNING:  Unknown GDAL driver: PNG at character 17
 20:32:51  t
 20:32:51  ERROR:  The pixel type of band 1 in the raster is not 8BUI or
 16BUI.  The PNG format can only be used with 8BUI and 16BUI pixel types.
 20:32:51 -1
 20:32:51 +ERROR:  rt_raster_to_gdal: Could not load the output GDAL driver
 20:32:51 -1
 20:32:51 -1
 20:32:51  NOTICE:  The PNG format only permits one, three or four bands.
 The first band will be used.
 20:32:51 -1
 20:32:51
 20:33:21  raster/test/regress/permitted_gdal_drivers .. failed (diff
 expected obtained:
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_311_diff)
 20:33:22
 20:33:22 --- ./raster/test/regress/permitted_gdal_drivers_expected
 2023-04-14 20:25:42.525312000 -0400
 20:33:22 +++
 /home/jenkins/tmp/pgis_reg_5da0ec6e80a4a1e414433e79289482c35ef32474/test_311_out
 2023-04-14 20:33:21.981975000 -0400
 20:33:22 @@ -1,3 +1,5 @@
 20:33:22 +WARNING:  Unknown GDAL driver: PNG
 20:33:22 +WARNING:  Unknown GDAL driver: JPEG
 20:33:22  4326
 20:33:22  ERROR:  RASTER_fromGDALRaster: Could not open bytea with GDAL.
 20:33:22  ERROR:  rt_band_load_offline_data: Cannot open offline raster:
 <VRTDataset rasterXSize="1000" rasterYSize="1"><VRTRasterBand band="1"
 subClass="VRTRawRasterBand"><SourceFilename>/etc/passwd</SourceFilename></VRTRasterBand></VRTDataset>
 20:33:22
 Before she was running with:
  -------------- Compiler Info -------------
 23:11:05   C compiler:           cc -std=gnu99 -g -O2 -fno-math-errno
 -fno-signed-zeros -Wall
 23:11:05   C++ compiler (Wagyu): cc -std=c++11 -x c++
 23:11:05   C++ compiler (FlatGeobuf): cc -std=c++11 -x c++
 23:11:05   CPPFLAGS:              -I/usr/local/include
 -I/usr/local/include -I/usr/local/include  -I/usr/local/include/libxml2
 -I/usr/local/include -I/usr/local/include -I/usr/local/include/json-c
 -I/usr/local/include  -DNDEBUG
 23:11:05   LDFLAGS:               -lm
 23:11:05   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
 23:11:05   Archiver:             llvm-ar rs
 23:11:05
 23:11:05  -------------- Additional Info -------------
 23:11:05   POSTGIS lib file includes minor:   ENABLED
 23:11:05   Interrupt Tests:   DISABLED use: --with-interrupt-tests to
 enable
 23:11:05
 23:11:05  -------------- Dependencies --------------
 23:11:05   GEOS config:          /usr/local/bin/geos-config
 23:11:05   GEOS version:         3.10.3
 23:11:05   GDAL config:          /usr/local/bin/gdal-config
 23:11:05   GDAL version:         3.5.0
 23:11:05   SFCGAL config:        /usr/local/bin/sfcgal-config
 23:11:05   SFCGAL version:       1.4.1
 23:11:05   PostgreSQL config:    /usr/local/bin/pg_config
 23:11:05   PostgreSQL version:   PostgreSQL 13.7
 23:11:05   PROJ4 version:        82
 23:11:05   Libxml2 config:       /usr/local/bin/xml2-config
 23:11:05   Libxml2 version:      2.9.13
 23:11:05   JSON-C support:       yes
 23:11:05   protobuf support:     yes
 23:11:05   protobuf-c version:   1004000
 23:11:05   PCRE support:         Version 2
 23:11:05   Perl:                 /usr/local/bin/perl
 23:11:05
 23:11:05  --------------- Extensions ---------------
 23:11:05   PostgreSQL EXTENSION support:       enabled
 23:11:05   PostGIS Raster:                     enabled
 23:11:05   PostGIS Topology:                   enabled
 23:11:05   SFCGAL support:                     enabled
 23:11:05   Address Standardizer support:       enabled
 23:11:05
 23:11:05  -------- Documentation Generation --------
 23:11:05   xsltproc:             /usr/local/bin/xsltproc
 23:11:05   xsl style sheets:
 23:11:05   dblatex:
 23:11:05   convert:              /usr/local/bin/convert
 23:11:05   mathml2.dtd:
 http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 23:11:05
 and now she is running:
 20:26:02  -------------- Dependencies --------------
 20:26:02   GEOS config:          /usr/local/bin/geos-config
 20:26:02   GEOS version:         3.11.1
 20:26:02   GDAL config:          /usr/local/bin/gdal-config
 20:26:02   GDAL version:         3.6.2
 20:26:02   SFCGAL config:        /usr/local/bin/sfcgal-config
 20:26:02   SFCGAL version:       1.4.1
 20:26:02   PostgreSQL config:    /usr/local/bin/pg_config
 20:26:02   PostgreSQL version:   PostgreSQL 13.10
 20:26:02   PROJ4 version:        92
 20:26:02   Libxml2 config:       /usr/local/bin/xml2-config
 20:26:02   Libxml2 version:      2.10.3
 20:26:02   JSON-C support:       yes
 20:26:02   protobuf support:     yes
 20:26:02   protobuf-c version:   1004001
 20:26:02   PCRE support:         Version 2
 20:26:02   Perl:                 /usr/local/bin/perl
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5370>
