[postgis-tickets] [PostGIS] #5367: Tiger extension loading invalid geometries
PostGIS trac at osgeo.org
Fri Apr 14 19:04:41 PDT 2023
  Reporter:  jnu             |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  low             |  Milestone:  PostGIS 3.3.3
 Component:  tiger geocoder  |    Version:  3.2.x
Resolution:                  |   Keywords:
Comment (by robe):
 I'll take a look and see. The places table comes straight from tiger. No
 massaging is done on that, so I would guess those errors are coming from
 census.
 I assume you are using 2022 data set?  You can check the
 tiger.loader_variables if you are not sure.
 Unfortunately I don't have the full set of states loaded, but I can add
 this step to the processing moving forward.
 By chance do you have all states loaded or just: AZ,IL,NC,TN
 I'm not seeing any invalids in the MA set, but perhaps there aren't any.
 The zcta5 set I am a bit surprised that one has invalids in it as that I
 do process to split and across state boundaries and thought I had a make
 valid step in there, but perhaps not.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5367#comment:1>
