[postgis-tickets] [PostGIS] #5371: Parallel ST_Union segfaults
PostGIS trac at osgeo.org
Mon Apr 17 12:29:27 PDT 2023
 Reporter:  ewie     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.3.3
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 Parallel `ST_Union` segfaults with PostGIS 3.3.2 on Postgres 11.19 and
 12.14 but not on 13.10.
 The query to trigger the segfault (see below for setup):
 BEGIN;
 SET LOCAL max_parallel_workers_per_gather = 2;
 --EXPLAIN
 SELECT r.name, st_union(a.geom)
 FROM area a
 JOIN region r ON r.id = a.region
 GROUP BY r.name;
 ROLLBACK;
 Produces this query plan on 11.19, 12.14, and 13.10:
                                               QUERY PLAN
  Finalize GroupAggregate  (cost=5198.72..5255.39 rows=200 width=35)
    Group Key: r.name
    ->  Gather Merge  (cost=5198.72..5245.39 rows=400 width=35)
          Workers Planned: 2
          ->  Sort  (cost=4198.70..4199.20 rows=200 width=35)
                Sort Key: r.name
                ->  Partial HashAggregate  (cost=4188.55..4191.05 rows=200
 width=35)
                      Group Key: r.name
                      ->  Hash Join  (cost=6.50..3874.92 rows=62727
 width=123)
                            Hash Cond: (a.region = r.id)
                            ->  Parallel Seq Scan on area a
 (cost=0.00..3700.27 rows=62727 width=128)
                            ->  Hash  (cost=4.00..4.00 rows=200 width=11)
                                  ->  Seq Scan on region r
 (cost=0.00..4.00 rows=200 width=11)
 (13 rows)
 The query does not segfault when disabling parallel queries with
 `max_parallel_workers_per_gather = 0`.
 Setup of schema and data (increase `num_areas` and `num_regions` if the
 query does not generate a parallel query plan):
 BEGIN;
 -- May need more rows to trigger a parallel query. Increase as necessary.
 \set num_areas 150000
 \set num_regions 200
 CREATE EXTENSION IF NOT EXISTS postgis;
 DROP TABLE IF EXISTS area;
 DROP TABLE IF EXISTS region;
 CREATE TABLE region (
   id bigint GENERATED ALWAYS AS IDENTITY PRIMARY KEY,
   name text NOT NULL
 CREATE TABLE area (
   geom geometry NOT NULL,
   region bigint NOT NULL,
   FOREIGN KEY (region) REFERENCES region (id)
 INSERT INTO region (name)
 SELECT
   s::text
 FROM
   generate_series(1, :num_regions) s;
 INSERT INTO area (geom, region)
 SELECT
   grid.geom,
   ((grid.i * grid.j) % :num_regions) + 1
 FROM
   st_squaregrid(
     1 / sqrt(:num_areas),
     st_geomfromtext('polygon ((0 0, 0 1, 1 1, 1 0, 0 0))')
   ) grid;
 ANALYZE area, region;
 COMMIT;
 Backtrace on 11.19:
 Program received signal SIGSEGV, Segmentation fault.
 pfree (pointer=0x560e05e96408) at utils/mmgr/mcxt.c:1035
 1035            context->methods->free_p(context, pointer);
 #0  pfree (pointer=0x560e05e96408) at utils/mmgr/mcxt.c:1035
 #1  list_free_private (deep=false, list=0x560e05f53dd8) at
 nodes/list.c:1117
 #2  list_free (list=0x560e05f53dd8) at nodes/list.c:1135
 #3  0x00007f23d20e4045 in state_combine (state2=0x560e04d56c58,
 state1=0x560e03675f00) at
 /usr/src/debug/postgis33_11-3.3.2-1.f37.x86_64/postgis/lwgeom_union.c:254
 #4  pgis_geometry_union_parallel_combinefn (fcinfo=<optimized out>) at
 /usr/src/debug/postgis33_11-3.3.2-1.f37.x86_64/postgis/lwgeom_union.c:107
 #5  0x0000560e027703a6 in ExecInterpExpr (state=0x560e05e4e040,
 econtext=0x560e03740768, isnull=<optimized out>) at
 executor/execExprInterp.c:1667
 #6  0x0000560e0278d93d in ExecEvalExprSwitchContext
 (isNull=0x7ffd4969af07, econtext=<optimized out>, state=<optimized out>)
 at executor/../../../src/include/executor/executor.h:320
 #7  advance_aggregates (aggstate=0x560e03740540) at executor/nodeAgg.c:670
 #8  agg_retrieve_direct (aggstate=0x560e03740540) at
 executor/nodeAgg.c:1838
 #9  ExecAgg (pstate=0x560e03740540) at executor/nodeAgg.c:1561
 #10 0x0000560e0277937a in ExecProcNode (node=0x560e03740540) at
 executor/../../../src/include/executor/executor.h:248
 #11 ExecutePlan (execute_once=<optimized out>, dest=0x560e0461ec50,
 direction=<optimized out>, numberTuples=0, sendTuples=true,
 operation=CMD_SELECT, use_parallel_mode=<optimized out>,
 planstate=0x560e03740540, estate=0x560e03740300) at
 executor/execMain.c:1712
 #12 standard_ExecutorRun (queryDesc=0x560e048feaf0, direction=<optimized
 out>, count=0, execute_once=<optimized out>) at executor/execMain.c:353
 #13 0x0000560e028ecb15 in ExecutorRun (execute_once=<optimized out>,
 count=0, direction=ForwardScanDirection, queryDesc=0x560e048feaf0) at
 executor/execMain.c:296
 #14 PortalRunSelect (portal=portal at entry=0x560e036f4f00,
 forward=forward at entry=true, count=0, count at entry=9223372036854775807,
 dest=dest at entry=0x560e0461ec50) at tcop/pquery.c:941
 #15 0x0000560e028ed41e in PortalRun (portal=portal at entry=0x560e036f4f00,
 count=count at entry=9223372036854775807, isTopLevel=isTopLevel at entry=true,
 run_once=run_once at entry=true, dest=dest at entry=0x560e0461ec50,
 altdest=altdest at entry=0x560e0461ec50, completionTag=0x7ffd4969b170 "") at
 tcop/pquery.c:782
 #16 0x0000560e028ed912 in exec_simple_query (query_string=0x560e0364ef90
 "SELECT\n r.name,\n st_union(a.geom) AS geom\nFROM area a\nJOIN region r
 ON r.id = a.region\nGROUP BY r.name;") at tcop/postgres.c:1144
 #17 0x0000560e028ef441 in PostgresMain (argc=<optimized out>,
 argv=<optimized out>, dbname=<optimized out>, username=<optimized out>) at
 tcop/postgres.c:4229
 #18 0x0000560e02873cd9 in BackendRun (port=0x560e036b7040) at
 postmaster/postmaster.c:4429
 #19 BackendStartup (port=0x560e036b7040) at postmaster/postmaster.c:4093
 #20 ServerLoop () at postmaster/postmaster.c:1728
 #21 0x0000560e02874c3c in PostmasterMain (argc=<optimized out>,
 argv=0x560e036498c0) at postmaster/postmaster.c:1401
 #22 0x0000560e025c1595 in main (argc=3, argv=0x560e036498c0) at
 main/main.c:228
 Backtrace on 12.14:
 pfree (pointer=0x7f4c5faed7f8) at utils/mmgr/mcxt.c:1035
 #0  pfree (pointer=0x7f4c5faed7f8) at utils/mmgr/mcxt.c:1035
 #1  list_free_private (deep=false, list=0x55db196c55c8) at
 nodes/list.c:1120
 #2  list_free (list=0x55db196c55c8) at nodes/list.c:1138
 #3  0x00007f4c60a31fa5 in state_combine (state2=0x55db196e2438,
 state1=0x55db195c2b90) at
 /usr/src/debug/postgis33_12-3.3.2-1.f37.x86_64/postgis/lwgeom_union.c:254
 /usr/src/debug/postgis33_12-3.3.2-1.f37.x86_64/postgis/lwgeom_union.c:107
 #5  0x000055db1865a4dc in ExecInterpExpr (state=0x55db19614b80,
 econtext=0x55db195a1898, isnull=<optimized out>) at
 executor/execExprInterp.c:1650
 #6  0x000055db186732dd in ExecEvalExprSwitchContext
 (isNull=0x7ffca8d295b7, econtext=<optimized out>, state=<optimized out>)
 at executor/../../../src/include/executor/executor.h:316
 #7  advance_aggregates (aggstate=0x55db195a1670) at executor/nodeAgg.c:669
 #8  agg_retrieve_direct (aggstate=0x55db195a1670) at
 #9  ExecAgg (pstate=0x55db195a1670) at executor/nodeAgg.c:1563
 #10 0x000055db1865d972 in ExecProcNode (node=0x55db195a1670) at
 executor/../../../src/include/executor/executor.h:242
 #11 ExecutePlan (execute_once=<optimized out>, dest=0x55db195a7438,
 planstate=0x55db195a1670, estate=0x55db195a13d0) at
 executor/execMain.c:1632
 #12 standard_ExecutorRun (queryDesc=0x55db194f6c20, direction=<optimized
 out>, count=0, execute_once=<optimized out>) at executor/execMain.c:350
 #13 0x000055db187e00d5 in ExecutorRun (execute_once=<optimized out>,
 count=0, direction=ForwardScanDirection, queryDesc=0x55db194f6c20) at
 executor/execMain.c:294
 #14 PortalRunSelect (portal=portal at entry=0x55db1953cc60,
 dest=dest at entry=0x55db195a7438) at tcop/pquery.c:938
 #15 0x000055db187e1b9e in PortalRun (portal=portal at entry=0x55db1953cc60,
 run_once=run_once at entry=true, dest=dest at entry=0x55db195a7438,
 altdest=altdest at entry=0x55db195a7438, completionTag=0x7ffca8d29820 "") at
 tcop/pquery.c:779
 #16 0x000055db187e209a in exec_simple_query (query_string=0x55db194cea90
 ON r.id = a.region\nGROUP BY r.name;") at tcop/postgres.c:1214
 #17 0x000055db187e412d in PostgresMain (argc=<optimized out>,
 tcop/postgres.c:4293
 #18 0x000055db18768587 in BackendRun (port=0x55db194f3fb0) at
 postmaster/postmaster.c:4517
 #19 BackendStartup (port=0x55db194f3fb0) at postmaster/postmaster.c:4200
 #20 ServerLoop () at postmaster/postmaster.c:1725
 #21 0x000055db187694b1 in PostmasterMain (argc=<optimized out>,
 argv=0x55db194898c0) at postmaster/postmaster.c:1398
 #22 0x000055db1849cf79 in main (argc=3, argv=0x55db194898c0) at
 main/main.c:228
 System:
 Linux fedora 6.2.10-200.fc37.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Apr  6
 23:30:41 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
 Postgres 11:
 -[ RECORD 1
 version              | PostgreSQL 11.19 on x86_64-pc-linux-gnu, compiled
 by gcc (GCC) 12.2.1 20221121 (Red Hat 12.2.1-4), 64-bit
 postgis_full_version | POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="110"
 GEOS="3.11.2-CAPI-1.17.2" PROJ="9.0.1" LIBXML="2.10.3" LIBJSON="0.16"
 LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
 Postgres 12:
 -[ RECORD 1
 version              | PostgreSQL 12.14 on x86_64-pc-linux-gnu, compiled
 postgis_full_version | POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="120"
 Postgres 13:
 -[ RECORD 1
 version              | PostgreSQL 13.10 on x86_64-pc-linux-gnu, compiled
 postgis_full_version | POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="130"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5371>
