[postgis-tickets] [PostGIS] #5373: Expose GEOSLargestEmptyCircle
PostGIS trac at osgeo.org
Wed Apr 19 15:28:47 PDT 2023
 Reporter:  mdavis       |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.3.3
Component:  postgis      |    Version:  3.3.x
 Keywords:               |
 GEOS has recently [https://github.com/libgeos/geos/pull/859 enhanced]
 `LargestEmptyCircle` so that it works correctly with polygonal boundaries.
 See the [https://github.com/locationtech/jts/pull/973 JTS PR] for more
 information.  It would be nice to expose this in PostGIS.
 Currently the LEC functionality is accessed via
 `ST_MaximumInscribedCircle` when the input is non-polygonal (lines and/or
 points).  I suggest exposing it directly via a new function
 `ST_LargestEmptyCircle(geom, boundary, tolerance)`. This has the
 advantages:
 * it provides an explicit boundary constraint polygon.  This will support
 queries such as "Find the furthest point in a jurisdiction from all
 roads".
 * it will allow polygonal obstacles (in the future, once the underlying
 algorithm is enhanced)
 * it allows more focussed documentation and examples
 The boundary is optional; if not provided the convex hull of the obstacles
 is used.  Perhaps the function signature should allow the `boundary`
 parameter to be optional?  Or else it can be allowed to be NULL.
 The existing `ST_MaximumInscribedCircle` behaviour can be left unchanged
 for backwards compatibility.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5373>
