[postgis-tickets] [PostGIS] #5374: PG16 failing
PostGIS trac at osgeo.org
Thu Apr 20 17:45:07 PDT 2023
#5374: PG16 failing
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 I thought this was a PG16 building issue, but I think they removed force
 parallel mode:
 18:11:29  regress/core/tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_85_diff)
 18:11:34
 18:11:34 --- ./regress/core/tickets_expected    2023-03-08
 01:57:17.656165431 +0000
 18:11:34 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_85_out
 2023-04-20 22:11:34.108224927 +0000
 18:11:34 @@ -276,8 +276,8 @@
 18:11:34  #3172|LINESTRING M (0 0 1,0 0 2)
 18:11:34  #3300|POLYGON((-71.7821 42.2622,-71.7821 42.9067,-71.029
 42.9067,-71.029 42.2622,-71.7821 42.2622))
 18:11:34  #3355|t
 18:11:34 -#3356|LineString[] with 2 points|LineString[GS] with 2
 points|LineString[GS] with 2 points
 18:11:34  #3356|LineString[B] with 3 points|LineString[BGS] with 3
 points|LineString[BGS] with 3 points
 18:11:34 +#3356|LineString[] with 2 points|LineString[GS] with 2
 18:11:34  #3367|POLYGON EMPTY
 18:11:34
 #3368|\x660001011fb98788d35ed6fbcdc831c580012b959f01469d8d0e9305ff8618ed08b1b607e302a614fe70bc4682b303b4379ab503a228eeb603e2138eb802900cc0b802ba04dab802b801a8840cb0229cca06f401c216f403a016ea05d0c301a8b301cc189226ac15ee27f811a029b40eac2ae00a902b8407c82b9e03d0e305801dfad3239504ce7e8d01e2f701f6019b04d1e2279bf901ff01
 18:11:34  #3375|GEOMETRYCOLLECTION(POINT(0 -7))
 18:11:34 @@ -463,7 +463,9 @@
 18:11:34  #5008|f|f
 18:11:34  ERROR:  Line has no points
 18:11:34  #5350|M 0 0 l 1 -1
 18:11:34 +ERROR:  unrecognized configuration parameter
 "force_parallel_mode"
 18:11:34  #5139|100000
 18:11:34  #5139|1000000
 18:11:34  ERROR:  Geometry contains invalid coordinates
 18:11:34
 18:11:34  regress/core/twkb .. ok in 65 ms
 18:11:34  regress/core/typmod .. ok in 6834 ms
 18:11:41  regress/core/wkb .. ok in 79 ms
 18:11:41  regress/core/wkt .. ok in 87 ms
 18:11:41  regress/core/wmsservers .. ok in 235 ms
 18:11:41  regress/core/offsetcurve .. ok in 61 ms
 18:11:41  regress/core/relatematch .. ok in 52 ms
 18:11:41  regress/core/isvaliddetail .. ok in 55 ms
 18:11:41  regress/core/sharedpaths .. ok in 72 ms
 18:11:42  regress/core/snap .. ok in 50 ms
 18:11:42  regress/core/node .. ok in 53 ms
 18:11:42  regress/core/unaryunion .. ok in 54 ms
 18:11:42  regress/core/union .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_98_diff)
 18:11:42
 18:11:42 --- ./regress/core/union_expected      2022-08-22
 20:53:14.519685332 +0000
 18:11:42 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg16w64/test_98_out
 2023-04-20 22:11:42.860196833 +0000
 18:11:42 @@ -4,6 +4,7 @@
 18:11:42  t
 18:11:42  POINT EMPTY
 18:11:42  POLYGON EMPTY
 18:11:42 +ERROR:  unrecognized configuration parameter
 18:11:42  400|0|0|20|20
 18:11:42  t
 18:11:42
 I suspect GHA would be failing at this step too, but is stuck on the CUnit
 tests #5366 on raster so never gets to this point.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5374>
