[postgis-tickets] [PostGIS] #5366: GHA last coverage is failing on raster GDAL polygonize cUnit test
PostGIS trac at osgeo.org
Thu Apr 20 21:09:54 PDT 2023
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 3.4.0
 Component:  raster  |    Version:  master
Resolution:          |   Keywords:
Comment (by robe):
 The answers are the same it's just the order of polygons and values in the
 array is different.
 I'm revising the tests to just sum the values and the areas so to not have
 to worry  about the order in the array.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5366#comment:3>
