[postgis-tickets] [PostGIS] #5375: topology tests failing on debbie PG16
PostGIS trac at osgeo.org
Thu Apr 20 21:31:58 PDT 2023
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.0
 Component:  topology  |    Version:  3.3.x
Resolution:            |   Keywords:  PostgreSQL 16 pg16
Comment (by robe):
 I think this may be the same issue as what I am seeing in tickets.
 I think the PG16 answer is wrong.
 Example:
 SELECT f.wkt
 FROM (VALUES (
      'LINESTRING(124.983539 1.419224,91.181596 29.647798)'::text ),
  ('LINESTRING(124.983539 1.419224,91.181596 29.647798, 91.28
 29.647)'::text  ) ) As f(wkt)
 ORDER BY f.wkt;
 In PG16, the sort is changed a bit.  I suppose this is more right, it's
 ranking space as alphabetically before parenthesis  )
                                 wkt
  LINESTRING(124.983539 1.419224,91.181596 29.647798, 91.28 29.647)
 (2 rows)
 For PG15 and below, this sorted as:
                                wkt
 (2 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5375#comment:2>
