[postgis-tickets] [PostGIS] #5366: GHA last coverage is failing on raster GDAL polygonize cUnit test
PostGIS trac at osgeo.org
Thu Apr 20 22:49:53 PDT 2023
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 3.2.4
 Component:  raster  |    Version:  master
Resolution:          |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"82288782d75f1d66cd74eb1aa19353c6aed1a69c/git" 8228878/git]:
 {{{#!CommitTicketReference repository="git"
 revision="82288782d75f1d66cd74eb1aa19353c6aed1a69c"
 Change gdal polygonize tests to be sum of areas and values
 instead of checking individual elements.
 This is to account for GDAL 3.7 results array sorted in different order
 from prior versions.
 References #5366 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5366#comment:5>
