[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-736-gaa3f0ceeb
Fri Apr 21 12:36:37 PDT 2023
the project "PostGIS".
       via  aa3f0ceeb0ad00f46d37656fa6931bfdd785a609 (commit)
      from  8d074fc3a2c7ab2f4677f71629a38a5cc13358ba (commit)
revisions in full, below.
commit aa3f0ceeb0ad00f46d37656fa6931bfdd785a609
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Apr 21 21:35:56 2023 +0200
    Force C locale and libc provider in regress test db with PG15+
    This is probably a workaround to a bug in PostgreSQL 16, but it
    feels like the smallest change to fix #5375
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 543eb7d64..3f143f225 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -285,6 +285,10 @@ psql -tAc "
 " template1
+my $pgvernum = `
+psql -tAc "SELECT current_setting('server_version_num')" template1
 my $defextver = `
 psql -XtAc "
 	SELECT default_version
@@ -323,7 +327,6 @@ else
-my $pgvernum = sql("SELECT current_setting('server_version_num')");
 my $libver = sql("select postgis_lib_version()");
 if ( ! $libver )
@@ -1441,7 +1444,11 @@ sub count_postgis_objects
 sub create_db
-	my $createcmd = "createdb --encoding=UTF-8 --template=template0 --lc-collate=C $DB > $REGRESS_LOG";
+	my $createcmd = "createdb --encoding=UTF-8 --template=template0 --lc-collate=C";
+	if ( $pgvernum ge 150000 ) {
+		$createcmd .= " --locale=C --locale-provider=libc"
+	$createcmd .= " $DB > $REGRESS_LOG";
 	return not system($createcmd);
Summary of changes:
 regress/run_test.pl | 11 +++++++++--
 1 file changed, 9 insertions(+), 2 deletions(-)
hooks/post-receive
