[postgis-tickets] [PostGIS] #5362: ERROR in ST_Intersects
PostGIS trac at osgeo.org
Tue Apr 25 08:59:43 PDT 2023
  Reporter:  tomasmarek  |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  3.3.x
Resolution:  fixed       |   Keywords:  ST_Intersects
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
 * milestone:  PostGIS 3.3.3 => PostGIS GEOS
Comment:
 Spoke to pramsey about this.  He said the intersects and intersection are
 separate code lines.
 GEOS doesn't plan to fix in lower versions since it would be too
 destabilizing.
 So I'm going to close this out as fixed in GEOS 3.12 (albeit, not yet
 released), but will be released probably in another 3-5 months.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5362#comment:4>
