[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-741-g92ca7e532
Tue Apr 25 11:26:47 PDT 2023
the project "PostGIS".
       via  92ca7e5329efe5d0834b60c6aab7f8ff44e81d6e (commit)
      from  cde98d9ffd293233bcc80a4ef932ba8a4aa37e75 (commit)
revisions in full, below.
commit 92ca7e5329efe5d0834b60c6aab7f8ff44e81d6e
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Apr 25 11:26:42 2023 -0700
    Improve doc for ST_Node and ST_UnaryUnion
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index 3f3a29bfc..84ebfbfe1 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -392,6 +392,11 @@ The resulting linework is dissolved (duplicate lines are removed).
         <para>This is a good way to create fully-noded linework suitable for use as input to <xref linkend="ST_Polygonize" />.</para>
+        <para><xref linkend="ST_UnaryUnion" /> can also be used to node and dissolve linework.
+        It provides an option to specify a gridSize, which can provide simpler and more robust output.
+        See also <xref linkend="ST_Union" /> for an aggregate variant.
+        </para>
         <para>&Z_support;</para>
         <para>Performed by the GEOS module.</para>
         <para>Availability: 2.0.0</para>
@@ -431,7 +436,7 @@ MULTILINESTRING((2 5,2 3),(2 3,2 1,4 1),(4 1,2 3),(4 1,6 1),(6 1,7 1))
         <title>See Also</title>
         <para>
-            <xref linkend="ST_UnaryUnion" />
+            <xref linkend="ST_UnaryUnion" />, <xref linkend="ST_Union" />
         </para>
       </refsection>
     </refentry>
@@ -904,8 +909,8 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
         Another use of this function is to node and dissolve a collection of
         linestrings which cross or overlap
         to make them <link linkend="Simple_Geometry">simple</link>.
-        (To add nodes but not dissolve duplicate linework
-        use <xref linkend="ST_Node" />.)
+        (<xref linkend="ST_Node" /> also does this,
+        but it does not provide the <code>gridSize</code> option.)
         </para>
         <para>
Summary of changes:
 doc/reference_overlay.xml | 11 ++++++++---
 1 file changed, 8 insertions(+), 3 deletions(-)
hooks/post-receive
