[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta2-13-g064e9b4ee
Tue Aug 1 09:22:45 PDT 2023
the project "PostGIS".
       via  064e9b4ee7c42dd2a0ab0aff2f7c232d033ef014 (commit)
      from  a84f3d0e7eb67b5bcf40aa97833576e68873c6b3 (commit)
revisions in full, below.
commit 064e9b4ee7c42dd2a0ab0aff2f7c232d033ef014
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Aug 1 09:22:44 2023 -0700
    Improve doc for clustering functions
diff --git a/doc/reference_cluster.xml b/doc/reference_cluster.xml
index e382bb354..a24e965ec 100644
--- a/doc/reference_cluster.xml
+++ b/doc/reference_cluster.xml
@@ -149,21 +149,21 @@ GROUP BY cid;
               <xref linkend="ST_ClusterIntersectingWin"/>
           </para>
 	  </refsection>
     </refentry>
-    <refentry id="ST_ClusterIntersectingWin">
+    <refentry id="ST_ClusterIntersecting">
       <refnamediv>
-        <refname>ST_ClusterIntersectingWin</refname>
+        <refname>ST_ClusterIntersecting</refname>
-        <refpurpose>Window function that returns a cluster id for each input geometry, clustering input geometries into connected sets.</refpurpose>
+        <refpurpose>Aggregate function that clusters input geometries into connected sets.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
         <funcsynopsis>
           <funcprototype>
-            <funcdef>integer <function>ST_ClusterIntersectingWin</function></funcdef>
-            <paramdef><type>geometry winset </type> <parameter>geom</parameter></paramdef>
+            <funcdef>geometry[] <function>ST_ClusterIntersecting</function></funcdef>
+            <paramdef><type>geometry set</type> <parameter>g</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -171,62 +171,59 @@ GROUP BY cid;
       <refsection>
         <title>Description</title>
-        <para>ST_ClusterIntersectingWin is a windowing function that builds inter-connecting clusters of geometries that intersect. It is possible to traverse all geometries in a cluster without leaving the cluster. The return value is the cluster number that the geometry argument participates in, or null for null inputs.</para>
+        <para>An aggregate function that returns an array of GeometryCollections
+        partitioning the input geometries into connected clusters that are disjoint.
+        Each geometry in a cluster intersects at least one other geometry in the cluster,
+        and does not intersect any geometry in other clusters.
+        </para>
-        <para role="availability" conformance="3.4.0">Availability: 3.4.0</para>
+        <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
       </refsection>
       <refsection>
         <title>Examples</title>
         <programlisting>
-WITH testdata AS (
-  SELECT id, geom::geometry FROM (
-  VALUES  (1, 'LINESTRING (0 0, 1 1)'),
-          (2, 'LINESTRING (5 5, 4 4)'),
-          (3, 'LINESTRING (6 6, 7 7)'),
-          (4, 'LINESTRING (0 0, -1 -1)'),
-          (5, 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))')) AS t(id, geom)
-SELECT id,
-  ST_AsText(geom),
-  ST_ClusterIntersectingWin(geom) OVER () AS cluster
-FROM testdata;
+WITH testdata AS
+  (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,
+           'LINESTRING (5 5, 4 4)'::geometry,
+           'LINESTRING (6 6, 7 7)'::geometry,
+           'LINESTRING (0 0, -1 -1)'::geometry,
+           'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
- id |           st_astext            | cluster
-  1 | LINESTRING(0 0,1 1)            |       0
-  2 | LINESTRING(5 5,4 4)            |       0
-  3 | LINESTRING(6 6,7 7)            |       1
-  4 | LINESTRING(0 0,-1 -1)          |       0
-  5 | POLYGON((0 0,4 0,4 4,0 4,0 0)) |       0
+SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;
+--result
+st_astext
+GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
+GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
         </programlisting>
       </refsection>
       <refsection>
         <title>See Also</title>
         <para>
-            <xref linkend="ST_ClusterDBSCAN" />,
-            <xref linkend="ST_ClusterKMeans" />,
+            <xref linkend="ST_ClusterIntersectingWin" />,
+            <xref linkend="ST_ClusterWithin" />,
             <xref linkend="ST_ClusterWithinWin" />
-            <xref linkend="ST_ClusterWithin" />
-            <xref linkend="ST_ClusterIntersecting" />
         </para>
       </refsection>
     </refentry>
-    <refentry id="ST_ClusterIntersecting">
+    <refentry id="ST_ClusterIntersectingWin">
       <refnamediv>
-        <refname>ST_ClusterIntersecting</refname>
+        <refname>ST_ClusterIntersectingWin</refname>
-        <refpurpose>Aggregate function that clusters input geometries into connected sets.</refpurpose>
+        <refpurpose>Window function that returns a cluster id for each input geometry, clustering input geometries into connected sets.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
         <funcsynopsis>
           <funcprototype>
-            <funcdef>geometry[] <function>ST_ClusterIntersecting</function></funcdef>
-            <paramdef><type>geometry set</type> <parameter>g</parameter></paramdef>
+            <funcdef>integer <function>ST_ClusterIntersectingWin</function></funcdef>
+            <paramdef><type>geometry winset </type> <parameter>geom</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -234,49 +231,49 @@ FROM testdata;
       <refsection>
-        <para>ST_ClusterIntersecting is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents an interconnected set of geometries.</para>
+        <para>A window function that builds connected clusters of geometries that intersect. It is possible to traverse all geometries in a cluster without leaving the cluster. The return value is the cluster number that the geometry argument participates in, or null for null inputs.</para>
-        <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
+        <para role="availability" conformance="3.4.0">Availability: 3.4.0</para>
       </refsection>
       <refsection>
         <programlisting>
-WITH testdata AS
-  (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,
-           'LINESTRING (5 5, 4 4)'::geometry,
-           'LINESTRING (6 6, 7 7)'::geometry,
-           'LINESTRING (0 0, -1 -1)'::geometry,
-           'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
-SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;
+WITH testdata AS (
+  SELECT id, geom::geometry FROM (
+  VALUES  (1, 'LINESTRING (0 0, 1 1)'),
+          (2, 'LINESTRING (5 5, 4 4)'),
+          (3, 'LINESTRING (6 6, 7 7)'),
+          (4, 'LINESTRING (0 0, -1 -1)'),
+          (5, 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))')) AS t(id, geom)
+SELECT id,
+  ST_AsText(geom),
+  ST_ClusterIntersectingWin(geom) OVER () AS cluster
+FROM testdata;
---result
+ id |           st_astext            | cluster
+  1 | LINESTRING(0 0,1 1)            |       0
+  2 | LINESTRING(5 5,4 4)            |       0
+  3 | LINESTRING(6 6,7 7)            |       1
+  4 | LINESTRING(0 0,-1 -1)          |       0
+  5 | POLYGON((0 0,4 0,4 4,0 4,0 0)) |       0
-st_astext
-GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
-GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
         </programlisting>
       </refsection>
       <refsection>
         <para>
+            <xref linkend="ST_ClusterIntersecting" />,
         </para>
       </refsection>
     </refentry>
 	<refentry id="ST_ClusterKMeans">
 	  <refnamediv>
 		<refname>ST_ClusterKMeans</refname>
@@ -420,7 +417,7 @@ from
       <refnamediv>
         <refname>ST_ClusterWithin</refname>
-        <refpurpose>Aggregate function that clusters input geometries by separation distance.</refpurpose>
+        <refpurpose>Aggregate function that clusters geometries by separation distance.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -436,7 +433,14 @@ from
       <refsection>
-        <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.  (Distances are Cartesian distances in the units of the SRID.)</para>
+        <para>An aggregate function that returns an array of GeometryCollections,
+        where each collection is a cluster containing some input geometries.
+        Clustering partitions the input geometries into sets,
+        in which each geometry is within the specified <parameter>distance</parameter>
+        of at least one other geometry in the same cluster.
+        Distances are Cartesian distances in the units of the SRID.
+        </para>
+        <para>ST_ClusterWithin is equivalent to running <xref linkend="ST_ClusterDBSCAN" /> with a `minpoints` of zero.</para>
         <para>&curve_support;</para>
@@ -465,11 +469,10 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
       <refsection>
         <para>
-          <xref linkend="ST_ClusterIntersectingWin"/>,
           <xref linkend="ST_ClusterWithinWin"/>,
-          <xref linkend="ST_ClusterIntersecting"/>
+          <xref linkend="ST_ClusterDBSCAN" />,
+          <xref linkend="ST_ClusterIntersecting"/>,
+          <xref linkend="ST_ClusterIntersectingWin"/>
         </para>
       </refsection>
@@ -495,7 +498,12 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
       <refsection>
-        <para>ST_ClusterWithinWin is a window function that returns an integer for each input geometry, where the integer the cluster number the geometry is a member of. Clusters represent a set of input geometries separated by no more than the specified distance. (Distances are Cartesian distances in the units of the SRID.)
+        <para>A window function that returns an integer for each input geometry,
+        which is the id of the cluster containing the geometry.
         </para>
         <para>ST_ClusterWithinWin is equivalent to running <xref linkend="ST_ClusterDBSCAN" /> with a `minpoints` of zero.</para>
@@ -533,11 +541,10 @@ FROM testdata;
       <refsection>
         <para>
+          <xref linkend="ST_ClusterWithin"/>,
-          <xref linkend="ST_ClusterWithin"/>,
         </para>
       </refsection>
Summary of changes:
 doc/reference_cluster.xml | 145 ++++++++++++++++++++++++----------------------
 1 file changed, 76 insertions(+), 69 deletions(-)
hooks/post-receive
