[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta2-15-g814059375
Tue Aug 1 22:14:33 PDT 2023
the project "PostGIS".
       via  8140593755a1c474b6b85bc7b1eabd37a2c78511 (commit)
      from  dddde0534621f07580682c3f8f229aaf8cb7d9a7 (commit)
revisions in full, below.
commit 8140593755a1c474b6b85bc7b1eabd37a2c78511
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Aug 1 22:14:31 2023 -0700
    Improve doc formatting for ClusterWithin
diff --git a/doc/reference_cluster.xml b/doc/reference_cluster.xml
index a24e965ec..7b88b6727 100644
--- a/doc/reference_cluster.xml
+++ b/doc/reference_cluster.xml
@@ -440,7 +440,7 @@ from
         of at least one other geometry in the same cluster.
         Distances are Cartesian distances in the units of the SRID.
         </para>
-        <para>ST_ClusterWithin is equivalent to running <xref linkend="ST_ClusterDBSCAN" /> with a `minpoints` of zero.</para>
+        <para>ST_ClusterWithin is equivalent to running <xref linkend="ST_ClusterDBSCAN" /> with <code>minpoints := 0</code>.</para>
         <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
         <para>&curve_support;</para>
@@ -505,7 +505,7 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
         </para>
-        <para>ST_ClusterWithinWin is equivalent to running <xref linkend="ST_ClusterDBSCAN" /> with a `minpoints` of zero.</para>
+        <para>ST_ClusterWithinWin is equivalent to running <xref linkend="ST_ClusterDBSCAN" /> with <code>minpoints := 0</code>.</para>
         <para role="availability" conformance="3.4.0">Availability: 3.4.0</para>
Summary of changes:
 doc/reference_cluster.xml | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
