[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta2-19-g632d83616
Wed Aug 2 18:06:20 PDT 2023
the project "PostGIS".
       via  632d836163931f8f0185c102d1b40f24be305144 (commit)
      from  5f15bb6a5826b2ca06d71dec88e3bd865f4ce47f (commit)
revisions in full, below.
commit 632d836163931f8f0185c102d1b40f24be305144
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Aug 2 21:05:21 2023 -0400
    DOC CHANGES
     - Put in template the geos conformance new format
     - Revise cheatsheet to also highlight GEOS 3.11 and 3.12
diff --git a/doc/po/de/reference_coverage.xml.po b/doc/po/de/reference_coverage.xml.po
index 4d96ef841..c9a1c82ce 100644
--- a/doc/po/de/reference_coverage.xml.po
+++ b/doc/po/de/reference_coverage.xml.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: ming 64gcc81\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-07-18 20:22+0000\n"
+"POT-Creation-Date: 2023-08-03 01:03+0000\n"
 "PO-Revision-Date: 2023-05-04 20:32+0000\n"
 "Last-Translator: Automatically generated\n"
 "Language-Team: none\n"
@@ -51,8 +51,8 @@ msgid ""
 msgstr ""
 #. Tag: title
-#: reference_coverage.xml:33 reference_coverage.xml:120
-#: reference_coverage.xml:203
+#: reference_coverage.xml:33 reference_coverage.xml:121
+#: reference_coverage.xml:204
 #, no-c-format
 msgid "Description"
 msgstr ""
@@ -120,33 +120,39 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:66 reference_coverage.xml:138
+#: reference_coverage.xml:66 reference_coverage.xml:139
 #, no-c-format
-msgid "Availability: 3.4.0 - requires GEOS >= 3.12.0"
+msgid "Availability: 3.4.0"
+msgstr ""
+#. Tag: para
+#: reference_coverage.xml:67 reference_coverage.xml:140
+#, no-c-format
+msgid "Requires GEOS >= 3.12.0"
 msgstr ""
 #. Tag: title
-#: reference_coverage.xml:70 reference_coverage.xml:143
-#: reference_coverage.xml:219
+#: reference_coverage.xml:71 reference_coverage.xml:144
+#: reference_coverage.xml:220
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:77
+#: reference_coverage.xml:78
 #, no-c-format
 msgid "Invalid edges caused by overlap and non-matching vertices"
 msgstr ""
 #. Tag: title
-#: reference_coverage.xml:87 reference_coverage.xml:177
-#: reference_coverage.xml:253
+#: reference_coverage.xml:88 reference_coverage.xml:178
+#: reference_coverage.xml:254
 #, no-c-format
 msgid "See Also"
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:88
+#: reference_coverage.xml:89
 #, no-c-format
 msgid ""
 ", <xref linkend=\"ST_CoverageUnion\"/>, <xref "
@@ -154,13 +160,13 @@ msgid ""
 msgstr ""
 #. Tag: refpurpose
-#: reference_coverage.xml:102
+#: reference_coverage.xml:103
 #, no-c-format
 msgid "Window function that simplifies the edges of a polygonal coverage."
 msgstr ""
 #. Tag: funcprototype
-#: reference_coverage.xml:107
+#: reference_coverage.xml:108
 #, no-c-format
 msgid ""
 "<funcdef>geometry <function>ST_CoverageSimplify</function></funcdef> "
@@ -171,7 +177,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:122
+#: reference_coverage.xml:123
 #, no-c-format
 msgid ""
 "A window function which simplifies the edges of polygons in a polygonal "
@@ -181,7 +187,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:127
+#: reference_coverage.xml:128
 #, no-c-format
 msgid ""
 "The simplification uses a variant of the <ulink url=\"https://en.wikipedia."
@@ -192,7 +198,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:132
+#: reference_coverage.xml:133
 #, no-c-format
 msgid ""
 "To simplify only the \"internal\" edges of the coverage (those that are "
@@ -201,7 +207,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:134
+#: reference_coverage.xml:135
 #, no-c-format
 msgid ""
 "If the input is not a valid coverage there may be unexpected artifacts in "
@@ -211,19 +217,19 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:154 reference_coverage.xml:230
+#: reference_coverage.xml:155 reference_coverage.xml:231
 #, no-c-format
 msgid "Input coverage"
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:164
+#: reference_coverage.xml:165
 #, no-c-format
 msgid "Simplified coverage"
 msgstr ""
 #. Tag: refpurpose
-#: reference_coverage.xml:189
+#: reference_coverage.xml:190
 #, no-c-format
 msgid ""
 "Computes the union of a set of polygons forming a coverage by removing "
@@ -231,7 +237,7 @@ msgid ""
 msgstr ""
-#: reference_coverage.xml:194
+#: reference_coverage.xml:195
 #, no-c-format
 msgid ""
 "<funcdef>geometry <function>ST_CoverageUnion</function></funcdef> "
@@ -239,7 +245,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:205
+#: reference_coverage.xml:206
 #, no-c-format
 msgid ""
 "An aggregate function which unions a set of polygons forming a polygonal "
@@ -250,7 +256,7 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:211
+#: reference_coverage.xml:212
 #, no-c-format
 msgid ""
@@ -259,19 +265,19 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:215
+#: reference_coverage.xml:216
 #, no-c-format
 msgid "Availability: 3.4.0 - requires GEOS >= 3.8.0"
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:240
+#: reference_coverage.xml:241
 #, no-c-format
 msgid "Union result"
 msgstr ""
 #. Tag: para
-#: reference_coverage.xml:254
+#: reference_coverage.xml:255
 #, no-c-format
 msgid ", <xref linkend=\"ST_Union\"/>"
 msgstr ""
diff --git a/doc/po/de/xsl-config.xml.po b/doc/po/de/xsl-config.xml.po
index cb629f173..9995cd986 100644
--- a/doc/po/de/xsl-config.xml.po
+++ b/doc/po/de/xsl-config.xml.po
@@ -55,7 +55,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
-"POT-Creation-Date: 2023-07-12 08:31+0000\n"
 "PO-Revision-Date: 2023-06-29 14:24+0000\n"
@@ -228,7 +228,7 @@ msgstr ""
 #. Tag: para
 #: xsl-config.xml:181
 #, no-c-format
-msgid "Requires GEOS 3.9 or higher"
+msgid "Requires GEOS (3.9,3.10,3.11,3.12) or higher"
 msgstr ""
 #. Tag: para
diff --git a/doc/po/es/reference_coverage.xml.po b/doc/po/es/reference_coverage.xml.po
index a7776df42..a34e8a77d 100644
--- a/doc/po/es/reference_coverage.xml.po
+++ b/doc/po/es/reference_coverage.xml.po
 msgstr ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr ""
 msgstr ""
 #. Tag: para
 #, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
diff --git a/doc/po/es/xsl-config.xml.po b/doc/po/es/xsl-config.xml.po
index dda3261bc..3dd618064 100644
--- a/doc/po/es/xsl-config.xml.po
+++ b/doc/po/es/xsl-config.xml.po
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
diff --git a/doc/po/fr/reference_coverage.xml.po b/doc/po/fr/reference_coverage.xml.po
index c974af94f..6baa645f7 100644
--- a/doc/po/fr/reference_coverage.xml.po
+++ b/doc/po/fr/reference_coverage.xml.po
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2023-05-29 09:08+0000\n"
 "Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
@@ -63,8 +63,8 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr "Description"
@@ -142,33 +142,39 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgstr "Disponibilité : 3.4.0 - nécessite GEOS >= 3.12.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr "Exemples"
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr "Voir aussi"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -176,13 +182,13 @@ msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr "Fonction window qui simplifie les bords d'une couverture polygonale."
 #, no-c-format
 msgid ""
@@ -198,7 +204,7 @@ msgstr ""
 "<parameter>simplifyBoundary = true</parameter></paramdef>"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -208,7 +214,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -219,7 +225,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -231,7 +237,7 @@ msgstr ""
 "<parameter>simplifyBoundary</parameter> à false."
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -241,19 +247,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -263,7 +269,7 @@ msgstr ""
 "supprimant les arêtes communes."
 #, no-c-format
 msgid ""
@@ -273,7 +279,7 @@ msgstr ""
 "<paramdef><type>geometry set</type> <parameter>geom</parameter></paramdef>"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -289,7 +295,7 @@ msgstr ""
 "pour calculer l'union beaucoup plus rapidement."
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -298,19 +304,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr "Disponibilité : 3.4.0 - nécessite GEOS >= 3.8.0"
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ", <xref linkend=\"ST_Union\"/>"
diff --git a/doc/po/fr/xsl-config.xml.po b/doc/po/fr/xsl-config.xml.po
index 36e3a1c42..059028a9e 100644
--- a/doc/po/fr/xsl-config.xml.po
+++ b/doc/po/fr/xsl-config.xml.po
@@ -68,7 +68,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2023-06-30 09:08+0000\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/xsl-config/"
@@ -264,7 +264,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
diff --git a/doc/po/it_IT/reference_coverage.xml.po b/doc/po/it_IT/reference_coverage.xml.po
index 2922c0618..264f6d1d4 100644
--- a/doc/po/it_IT/reference_coverage.xml.po
+++ b/doc/po/it_IT/reference_coverage.xml.po
 msgstr ""
 "PO-Revision-Date: 2023-05-14 05:08+0000\n"
 "Last-Translator: Regina Obe <regina at arrival3d.com>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
@@ -54,8 +54,8 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr ""
@@ -123,33 +123,39 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr "Si veda anche"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -157,13 +163,13 @@ msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -174,7 +180,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -184,7 +190,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -195,7 +201,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -204,7 +210,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -214,19 +220,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -234,7 +240,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
@@ -242,7 +248,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -253,7 +259,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -262,19 +268,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
diff --git a/doc/po/it_IT/xsl-config.xml.po b/doc/po/it_IT/xsl-config.xml.po
index 411950eb9..254a0fb3f 100644
--- a/doc/po/it_IT/xsl-config.xml.po
+++ b/doc/po/it_IT/xsl-config.xml.po
@@ -3,7 +3,7 @@ msgid ""
 msgstr ""
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
@@ -158,8 +158,8 @@ msgstr "Funzione finestra"
 #. Tag: para
 #, no-c-format
-msgstr "Richiede GEOS 3.9 o superiore"
+msgstr ""
 #. Tag: para
 #: xsl-config.xml:184
diff --git a/doc/po/ja/reference_coverage.xml.po b/doc/po/ja/reference_coverage.xml.po
index 7b65a8406..5e5248bf0 100644
--- a/doc/po/ja/reference_coverage.xml.po
+++ b/doc/po/ja/reference_coverage.xml.po
 msgstr ""
 "PO-Revision-Date: 2023-07-14 10:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
@@ -64,8 +64,8 @@ msgstr ""
 "parameter></paramdef>"
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr "説明"
@@ -150,33 +150,39 @@ msgstr ""
 "linkend=\"ST_IsValid\"/>でチェックできます。"
 #. Tag: para
 #, no-c-format
-msgstr "Availability: 3.4.0 - GEOS 3.12.0以上が必要です"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr "例"
 #. Tag: para
 #, no-c-format
 msgstr "オーバラップと頂点不一致により発生した不正エッジ"
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr "関連情報"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -186,13 +192,13 @@ msgstr ""
 "linkend=\"ST_CoverageSimplify\"/>"
 #. Tag: refpurpose
 #, no-c-format
 msgstr "ポリゴンカバレッジのエッジを単純化するウィンドウ関数。"
 #, no-c-format
 msgid ""
@@ -208,7 +214,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -221,7 +227,7 @@ msgstr ""
 "エッジに沿って構成され、妥当なカバレッジを形成します。"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -236,7 +242,7 @@ msgstr ""
 "純化する三角形面積の平方根とだいたい同じです。"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -247,7 +253,7 @@ msgstr ""
 "には、<parameter>simplifyBoundary</parameter>パラメタをFALSEに設定します。"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -261,19 +267,19 @@ msgstr ""
 "linkend=\"ST_CoverageInvalidEdges\"/>を使います。"
 #. Tag: para
 #, no-c-format
 msgstr "入力カバレッジ"
 #. Tag: para
 #, no-c-format
 msgstr "カバレッジの単純化"
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -283,7 +289,7 @@ msgstr ""
 "計算します。"
 #, no-c-format
 msgid ""
@@ -293,7 +299,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -308,7 +314,7 @@ msgstr ""
 "構造を使用します。"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -321,19 +327,19 @@ msgstr ""
 "す。"
 #. Tag: para
 #, no-c-format
 msgstr "Availability: 3.4.0 - GEOS 3.8.0以上が必要です"
 #. Tag: para
 #, no-c-format
 msgstr "結合結果"
 #. Tag: para
 #, no-c-format
diff --git a/doc/po/ja/xsl-config.xml.po b/doc/po/ja/xsl-config.xml.po
index 210a1322d..f2edde508 100644
--- a/doc/po/ja/xsl-config.xml.po
+++ b/doc/po/ja/xsl-config.xml.po
 msgstr ""
 "PO-Revision-Date: 2023-07-14 02:08+0000\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/xsl-"
@@ -209,8 +209,8 @@ msgstr "ウィンドウ関数"
 #. Tag: para
 #, no-c-format
-msgstr "GEOS 3.9以上が必要"
+msgstr ""
 #. Tag: para
diff --git a/doc/po/ko_KR/reference_coverage.xml.po b/doc/po/ko_KR/reference_coverage.xml.po
index 9c6529ae2..f57b25573 100644
--- a/doc/po/ko_KR/reference_coverage.xml.po
+++ b/doc/po/ko_KR/reference_coverage.xml.po
 msgstr ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr ""
 msgstr ""
 #. Tag: para
 #, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
diff --git a/doc/po/ko_KR/xsl-config.xml.po b/doc/po/ko_KR/xsl-config.xml.po
index cf5136e9b..2323944bb 100644
--- a/doc/po/ko_KR/xsl-config.xml.po
+++ b/doc/po/ko_KR/xsl-config.xml.po
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
diff --git a/doc/po/pl/reference_coverage.xml.po b/doc/po/pl/reference_coverage.xml.po
index 4a0081e04..d693da3e9 100644
--- a/doc/po/pl/reference_coverage.xml.po
+++ b/doc/po/pl/reference_coverage.xml.po
 msgstr ""
@@ -52,8 +52,8 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr ""
@@ -121,33 +121,39 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -155,13 +161,13 @@ msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -172,7 +178,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -182,7 +188,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -193,7 +199,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -202,7 +208,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -212,19 +218,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -232,7 +238,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
@@ -240,7 +246,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -251,7 +257,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -260,19 +266,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
diff --git a/doc/po/pl/xsl-config.xml.po b/doc/po/pl/xsl-config.xml.po
index a2feb7db5..0e8047d01 100644
--- a/doc/po/pl/xsl-config.xml.po
+++ b/doc/po/pl/xsl-config.xml.po
 msgstr ""
@@ -241,7 +241,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
diff --git a/doc/po/pt_BR/reference_coverage.xml.po b/doc/po/pt_BR/reference_coverage.xml.po
index 9d2ab5427..945635b1f 100644
--- a/doc/po/pt_BR/reference_coverage.xml.po
+++ b/doc/po/pt_BR/reference_coverage.xml.po
 msgstr ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr ""
 msgstr ""
 #. Tag: para
 #, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
diff --git a/doc/po/pt_BR/xsl-config.xml.po b/doc/po/pt_BR/xsl-config.xml.po
index 188070ceb..437d8bea8 100644
--- a/doc/po/pt_BR/xsl-config.xml.po
+++ b/doc/po/pt_BR/xsl-config.xml.po
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
diff --git a/doc/po/ru/reference_coverage.xml.po b/doc/po/ru/reference_coverage.xml.po
index 3b9cb79f1..f3312a3bb 100644
--- a/doc/po/ru/reference_coverage.xml.po
+++ b/doc/po/ru/reference_coverage.xml.po
 msgstr ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr ""
 msgstr ""
 #. Tag: para
 #, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
diff --git a/doc/po/ru/xsl-config.xml.po b/doc/po/ru/xsl-config.xml.po
index f23cf8175..0a126a214 100644
--- a/doc/po/ru/xsl-config.xml.po
+++ b/doc/po/ru/xsl-config.xml.po
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
diff --git a/doc/po/templates/reference_coverage.xml.pot b/doc/po/templates/reference_coverage.xml.pot
index 89ba23cfc..01cefa657 100644
--- a/doc/po/templates/reference_coverage.xml.pot
+++ b/doc/po/templates/reference_coverage.xml.pot
 msgstr ""
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -50,8 +50,8 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Description"
 msgstr ""
@@ -119,33 +119,39 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "See Also"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -153,13 +159,13 @@ msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -170,7 +176,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -180,7 +186,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -191,7 +197,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -200,7 +206,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -210,19 +216,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -230,7 +236,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
@@ -238,7 +244,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -249,7 +255,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -258,19 +264,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
diff --git a/doc/po/templates/xsl-config.xml.pot b/doc/po/templates/xsl-config.xml.pot
index b17dc0fb4..dbe243dde 100644
--- a/doc/po/templates/xsl-config.xml.pot
+++ b/doc/po/templates/xsl-config.xml.pot
 msgstr ""
@@ -152,7 +152,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index b6fc6250e..247497400 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -63,7 +63,8 @@
       This can be checked with <xref linkend="ST_IsValid" />.
       </para>
-      <para role="availability" conformance="3.4.0">Availability: 3.4.0 - requires GEOS >= 3.12.0</para>
+      <para role="availability" conformance="3.4.0">Availability: 3.4.0</para>
+      <para role="geos_requirement" conformance="3.12.0">Requires GEOS >= 3.12.0</para>
     </refsection>
     <refsection>
@@ -145,7 +146,7 @@ SELECT true = ALL (
       </para>
       <para>The simplification uses a variant of the <ulink url="https://en.wikipedia.org/wiki/Visvalingam%E2%80%93Whyatt_algorithm">Visvalingam–Whyatt algorithm</ulink>.
-      The <parameter>tolerance</parameter> parameter has units of distance,
+      The <parameter>tolerance</parameter> parameter has units of distance,
       and is roughly equal to the square root of triangular areas to be simplified.
       </para>
@@ -155,8 +156,8 @@ SELECT true = ALL (
       Use <xref linkend="ST_CoverageInvalidEdges" /> to determine if a coverage is valid.
       </para></note>
     </refsection>
     <refsection>
diff --git a/doc/template.xml b/doc/template.xml
index 5d1c09479..70d4dde58 100644
--- a/doc/template.xml
+++ b/doc/template.xml
@@ -54,7 +54,10 @@
       geometries.</para>
     </note>
     <!-- use this format if new function -->
-	<para role="availability" conformance="2.0.0">Availability: 2.0.0 - requires GEOS >= 3.3.0. </para>
+	<para role="availability" conformance="2.0.0">Availability: 2.0.0</para>
+    <!--conditionally specify GEOS minimum version -->
+    <para role="geos_requirement" conformance="3.9.0">Requires GEOS >= 3.9.0</para>
 	<!-- use this format if not a new function but functionality enhanced -->
 	<para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
diff --git a/doc/xsl-config.xml b/doc/xsl-config.xml
index 4ddae4c99..ebf6e81e4 100644
--- a/doc/xsl-config.xml
+++ b/doc/xsl-config.xml
@@ -179,7 +179,7 @@
 				Window function
         </para>
         <para role="requires_geos_3.9_or_higher">
-				Requires GEOS 3.9 or higher
+				Requires GEOS (3.9,3.10,3.11,3.12) or higher
         </para>
         <para role="z_support">
 				2.5/3D support
diff --git a/doc/xsl/common_cheatsheet.xsl b/doc/xsl/common_cheatsheet.xsl
index 6b742fc10..2b053b11a 100644
--- a/doc/xsl/common_cheatsheet.xsl
+++ b/doc/xsl/common_cheatsheet.xsl
@@ -9,7 +9,7 @@
 <xsl:variable name='sqlmm_conformance_tag' select='"sqlmm"' />
 <xsl:variable name='Z_conformance_tag' select='"3d"' />
 <xsl:variable name='geography_tag' select='"geography_support"' />
+<xsl:variable name='curve_conformance_tag' select='"curve"' />
 <xsl:variable name='include_examples'>false</xsl:variable>
 <xsl:variable name='output_purpose'>true</xsl:variable>
 <xsl:variable name='linkstub'>https://postgis.net/docs/manual-<xsl:value-of select="$postgis_version" />/<xsl:value-of select="$postgis_language" /></xsl:variable>
@@ -118,6 +118,15 @@
 		<xsl:if test="$ref//para[@role=$geos_tag and starts-with(./@conformance, '3.9')]">
 			 <sup>g3.9</sup>
 		</xsl:if>
+		<xsl:if test="$ref//para[@role=$geos_tag and starts-with(./@conformance, '3.10')]">
+			 <sup>g3.10</sup>
+		</xsl:if>
+		<xsl:if test="$ref//para[@role=$geos_tag and starts-with(./@conformance, '3.11')]">
+			 <sup>g3.11</sup>
+		</xsl:if>
+		<xsl:if test="$ref//para[@role=$geos_tag and starts-with(./@conformance, '3.12')]">
+			 <sup>g3.12</sup>
+		</xsl:if>
 		<xsl:if test="$ref/descendant::*[@conformance=$Z_conformance_tag]">
 			 <sup>3d</sup>
 		</xsl:if>
diff --git a/doc/xsl/postgis_cheatsheet.html.xsl b/doc/xsl/postgis_cheatsheet.html.xsl
index 4455ac67e..41bd84206 100644
--- a/doc/xsl/postgis_cheatsheet.html.xsl
+++ b/doc/xsl/postgis_cheatsheet.html.xsl
@@ -138,7 +138,7 @@ code {font-size: 8pt}
 				<xsl:value-of select="$cheatsheets_config/para[@role='window_function']" />
 					<sup>W</sup>
 				<xsl:value-of select="$cheatsheets_config/para[@role='requires_geos_3.9_or_higher']" />
-					<sup>g3.9</sup>
+					<sup>g3.9</sup> <sup>g3.11</sup> <sup>g3.12</sup>
 				<xsl:value-of select="$cheatsheets_config/para[@role='z_support']" />
 					<sup>3d</sup>
 				SQL-MM<sup>mm</sup>
Summary of changes:
 doc/po/de/reference_coverage.xml.po         | 58 +++++++++++++++-------------
 doc/po/de/xsl-config.xml.po                 |  4 +-
 doc/po/es/reference_coverage.xml.po         | 58 +++++++++++++++-------------
 doc/po/es/xsl-config.xml.po                 |  4 +-
 doc/po/fr/reference_coverage.xml.po         | 60 ++++++++++++++++-------------
 doc/po/fr/xsl-config.xml.po                 |  4 +-
 doc/po/it_IT/reference_coverage.xml.po      | 58 +++++++++++++++-------------
 doc/po/it_IT/xsl-config.xml.po              |  6 +--
 doc/po/ja/reference_coverage.xml.po         | 60 ++++++++++++++++-------------
 doc/po/ja/xsl-config.xml.po                 |  6 +--
 doc/po/ko_KR/reference_coverage.xml.po      | 58 +++++++++++++++-------------
 doc/po/ko_KR/xsl-config.xml.po              |  4 +-
 doc/po/pl/reference_coverage.xml.po         | 58 +++++++++++++++-------------
 doc/po/pl/xsl-config.xml.po                 |  4 +-
 doc/po/pt_BR/reference_coverage.xml.po      | 58 +++++++++++++++-------------
 doc/po/pt_BR/xsl-config.xml.po              |  4 +-
 doc/po/ru/reference_coverage.xml.po         | 58 +++++++++++++++-------------
 doc/po/ru/xsl-config.xml.po                 |  4 +-
 doc/po/templates/reference_coverage.xml.pot | 58 +++++++++++++++-------------
 doc/po/templates/xsl-config.xml.pot         |  4 +-
 doc/reference_coverage.xml                  |  9 +++--
 doc/template.xml                            |  5 ++-
 doc/xsl-config.xml                          |  2 +-
 doc/xsl/common_cheatsheet.xsl               | 11 +++++-
 doc/xsl/postgis_cheatsheet.html.xsl         |  2 +-
 25 files changed, 365 insertions(+), 292 deletions(-)
hooks/post-receive
