[postgis-tickets] [PostGIS] #5466: Turn off doc checks on translations that are far from done
PostGIS trac at osgeo.org
Thu Aug 3 20:26:58 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"af3e63085419434590f2d52963ca89105e52492f/git"
 af3e6308/git]:
 {{{#!CommitTicketReference repository="git"
 revision="af3e63085419434590f2d52963ca89105e52492f"
 Also take out cheatsheet, html, and pdf build
 checks for uncommon languages
 References #5466 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5466#comment:2>
