[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-5-g07c0f1b74
Mon Aug 7 03:08:45 PDT 2023
the project "PostGIS".
       via  07c0f1b746b827a75b43429b1730b8fc68f4f699 (commit)
       via  05473dfb0e66c5c00be72c466be98c22277b1a05 (commit)
       via  e4d108d1c3143b1b9566b10f19f88341e6f34a2e (commit)
      from  111e4a133b3e036cf634826ab05e7217ebc81cbf (commit)
revisions in full, below.
commit 07c0f1b746b827a75b43429b1730b8fc68f4f699
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Mon Aug 7 08:58:48 2023 +0000
    Translated xsl-config using Weblate (Japanese)
    Currently translated at 100.0% (24 of 24 strings)
    Translation: postgis/xsl-config
    Translate-URL: https://weblate.osgeo.org/projects/postgis/xsl-config/ja/
diff --git a/doc/po/ja/xsl-config.xml.po b/doc/po/ja/xsl-config.xml.po
index f2edde508..2c9cc674d 100644
--- a/doc/po/ja/xsl-config.xml.po
+++ b/doc/po/ja/xsl-config.xml.po
@@ -56,10 +56,10 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-08-03 01:03+0000\n"
-"PO-Revision-Date: 2023-07-14 02:08+0000\n"
+"PO-Revision-Date: 2023-08-07 10:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/xsl-"
-"config/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"xsl-config/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -210,7 +210,7 @@ msgstr "ウィンドウ関数"
 #: xsl-config.xml:181
 #, no-c-format
 msgid "Requires GEOS (3.9,3.10,3.11,3.12) or higher"
-msgstr ""
+msgstr "GEOS (3.9,3.10,3.11,3.12) 以上"
 #. Tag: para
 #: xsl-config.xml:184
commit 05473dfb0e66c5c00be72c466be98c22277b1a05
Date:   Mon Aug 7 09:05:06 2023 +0000
    Translated reference_coverage using Weblate (Japanese)
    Currently translated at 100.0% (33 of 33 strings)
    Translation: postgis/reference_coverage
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_coverage/ja/
diff --git a/doc/po/ja/reference_coverage.xml.po b/doc/po/ja/reference_coverage.xml.po
index 5e5248bf0..d8bd20629 100644
--- a/doc/po/ja/reference_coverage.xml.po
+++ b/doc/po/ja/reference_coverage.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: ming 64gcc81\n"
-"PO-Revision-Date: 2023-07-14 10:08+0000\n"
 "reference_coverage/ja/>\n"
@@ -153,13 +153,13 @@ msgstr ""
 #: reference_coverage.xml:66 reference_coverage.xml:139
 #, no-c-format
 msgid "Availability: 3.4.0"
-msgstr ""
+msgstr "Availability: 3.4.0"
 #. Tag: para
 #: reference_coverage.xml:67 reference_coverage.xml:140
 #, no-c-format
 msgid "Requires GEOS >= 3.12.0"
-msgstr ""
+msgstr "GEOS 3.12.0以上が必要です"
 #. Tag: title
 #: reference_coverage.xml:71 reference_coverage.xml:144
commit e4d108d1c3143b1b9566b10f19f88341e6f34a2e
Date:   Mon Aug 7 09:03:51 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (46 of 46 strings)
    Translation: postgis/release_notes.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/release_notesxml/ja/
diff --git a/doc/po/ja/release_notes.xml.po b/doc/po/ja/release_notes.xml.po
index 6114dd081..501ad501a 100644
--- a/doc/po/ja/release_notes.xml.po
+++ b/doc/po/ja/release_notes.xml.po
@@ -8,7 +8,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2023-08-03 00:19+0000\n"
-"PO-Revision-Date: 2023-08-01 03:08+0000\n"
 "release_notesxml/ja/>\n"
@@ -267,6 +267,8 @@ msgid ""
 "New coverage functions ST_CoverageInvalidEdges, ST_CoverageSimplify, "
 "ST_CoverageUnion (Paul Ramsey)"
 msgstr ""
+"新カバレッジ関数 ST_CoverageInvalidEdges, ST_CoverageSimplify, "
+"ST_CoverageUnion (Paul Ramseyさん)"
 #. Tag: title
 #: release_notes.xml:39
@@ -465,3 +467,5 @@ msgid ""
 "<ulink url=\"https://github.com/postgis/postgis/pull/5447\">5447</ulink>, "
 "postgis_restore.pl renamed to postgis_restore (Regina Obe)"
 msgstr ""
+"<ulink url=\"https://github.com/postgis/postgis/pull/5447\">5447</ulink>, "
+"postgis_restore.plをpostgis_restoreにファイル名変更 (Regina Obeさん)"
Summary of changes:
 doc/po/ja/reference_coverage.xml.po | 6 +++---
 doc/po/ja/release_notes.xml.po      | 6 +++++-
 doc/po/ja/xsl-config.xml.po         | 8 ++++----
 3 files changed, 12 insertions(+), 8 deletions(-)
hooks/post-receive
