[postgis-tickets] [PostGIS] #5470: make installcheck for address_standardizer expects incorrectly formatted output
PostGIS trac at osgeo.org
Tue Aug 8 00:55:50 PDT 2023
output
  Reporter:  tbussmann            |      Owner:  robe
      Type:  defect               |     Status:  new
  Priority:  medium               |  Milestone:  PostGIS 3.4.0
 Component:  pagc_address_parser  |    Version:  master
Resolution:                       |   Keywords:
Comment (by tbussmann):
 Yes, you remember correctly - a similar issue was fixed in [e6d6be31/git]
 (master) and [a5c0cb9/git] (3.3) but for a different test `test-
 standardize_address_1`. Seeing this kind of issue repeatedly, looks like
 there is an issue with the editor or git config somewhere.
 The patch attached to this ticket should fix it. Or do you prefer a PR?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5470#comment:2>
