[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-8-g0218f38fe
git at osgeo.org
git at osgeo.org
Tue Aug 8 11:16:02 PDT 2023
the project "PostGIS".
via 0218f38fe1ac47e27e71ec1675e6b027fe85b596 (commit)
from 60f5ae20dd6d8790b58ac19cde9f04639b573358 (commit)
revisions in full, below.
commit 0218f38fe1ac47e27e71ec1675e6b027fe85b596
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Aug 8 11:31:35 2023 +0200
[woodie] Regenerated docs.yml with update-docs-localized.sh
Writes subset of languages to be built in the script
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 396cd9720..299d688e4 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -84,63 +84,17 @@ steps:
# DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
### TARGET check-xml
- # check-xml-it_IT:
- # image: *test_image
- # commands:
- # - make -C build-docs/doc/po/it_IT local-check-xml
- # group: localized-check-xml
- # when:
- # path:
- # include:
- # # Localized assets
- # - "doc/po/it_IT/Makefile.in"
- # - "doc/po/it_IT/*.po"
- # - "utils/check_localized_cheatsheets.sh"
- # # Common docs path
- # # related config files
- # - ".woodpecker/docs.yml"
- # # Makefiles
- # - "doc/Makefile.in"
- # - "doc/html/images/Makefile.in"
- # # XML sources
- # - "doc/*.xml"
- # # Internationalization Makefiles
- # - "doc/po/Makefile.local"
- # # END OF COMMON PATHS
- # check-xml-pt_BR:
- # commands:
- # - make -C build-docs/doc/po/pt_BR local-check-xml
- # when:
- # path:
- # include:
- # - "doc/po/pt_BR/Makefile.in"
- # - "doc/po/pt_BR/*.po"
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- check-xml-fr:
+ check-xml-ja:
image: *test_image
commands:
- - make -C build-docs/doc/po/fr local-check-xml
+ - make -C build-docs/doc/po/ja local-check-xml
when:
path:
include:
# Localized assets
- - "doc/po/fr/Makefile.in"
- - "doc/po/fr/*.po"
+ - "doc/po/ja/Makefile.in"
+ - "doc/po/ja/*.po"
# Common docs path
@@ -153,75 +107,6 @@ steps:
- # check-xml-es:
- # commands:
- # - make -C build-docs/doc/po/es local-check-xml
- # when:
- # path:
- # include:
- # - "doc/po/es/Makefile.in"
- # - "doc/po/es/*.po"
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # check-xml-pl:
- # commands:
- # - make -C build-docs/doc/po/pl local-check-xml
- # when:
- # path:
- # include:
- # - "doc/po/pl/Makefile.in"
- # - "doc/po/pl/*.po"
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # check-xml-ko_KR:
- # commands:
- # - make -C build-docs/doc/po/ko_KR local-check-xml
- # when:
- # path:
- # include:
- # - "doc/po/ko_KR/Makefile.in"
- # - "doc/po/ko_KR/*.po"
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
check-xml-de:
image: *test_image
commands:
@@ -245,17 +130,17 @@ steps:
- check-xml-ja:
+ check-xml-fr:
image: *test_image
commands:
- - make -C build-docs/doc/po/ja local-check-xml
+ - make -C build-docs/doc/po/fr local-check-xml
when:
path:
include:
# Localized assets
- - "doc/po/ja/Makefile.in"
- - "doc/po/ja/*.po"
+ - "doc/po/fr/Makefile.in"
+ - "doc/po/fr/*.po"
# Common docs path
@@ -268,87 +153,18 @@ steps:
- # check-xml-ru:
- # commands:
- # - make -C build-docs/doc/po/ru local-check-xml
- # when:
- # path:
- # include:
- # - "doc/po/ru/Makefile.in"
- # - "doc/po/ru/*.po"
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
### TARGET html
- # html-it_IT:
- # commands:
- # - make -C build-docs/doc/po/it_IT local-html
- # group: localized-html
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # html-pt_BR:
- # commands:
- # - make -C build-docs/doc/po/pt_BR local-html
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- html-fr:
+ html-ja:
image: *test_image
commands:
- - make -C build-docs/doc/po/fr local-html
+ - make -C build-docs/doc/po/ja local-html
when:
path:
include:
# Localized assets
# Common docs path
@@ -361,75 +177,6 @@ steps:
- # html-es:
- # commands:
- # - make -C build-docs/doc/po/es local-html
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # html-pl:
- # commands:
- # - make -C build-docs/doc/po/pl local-html
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # html-ko_KR:
- # commands:
- # - make -C build-docs/doc/po/ko_KR local-html
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
html-de:
image: *test_image
commands:
@@ -453,17 +200,17 @@ steps:
- html-ja:
+ html-fr:
image: *test_image
commands:
- - make -C build-docs/doc/po/ja local-html
+ - make -C build-docs/doc/po/fr local-html
when:
path:
include:
# Localized assets
# Common docs path
@@ -476,87 +223,18 @@ steps:
- # html-ru:
- # commands:
- # - make -C build-docs/doc/po/ru local-html
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
### TARGET cheatsheets
- # cheatsheets-it_IT:
- # commands:
- # - make -C build-docs/doc/po/it_IT local-cheatsheets
- # group: localized-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # cheatsheets-pt_BR:
- # commands:
- # - make -C build-docs/doc/po/pt_BR local-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- cheatsheets-fr:
+ cheatsheets-ja:
image: *test_image
commands:
- - make -C build-docs/doc/po/fr local-cheatsheets
+ - make -C build-docs/doc/po/ja local-cheatsheets
when:
path:
include:
# Localized assets
# Common docs path
@@ -569,75 +247,6 @@ steps:
- # cheatsheets-es:
- # commands:
- # - make -C build-docs/doc/po/es local-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # cheatsheets-pl:
- # commands:
- # - make -C build-docs/doc/po/pl local-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # cheatsheets-ko_KR:
- # commands:
- # - make -C build-docs/doc/po/ko_KR local-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
cheatsheets-de:
image: *test_image
commands:
@@ -661,104 +270,11 @@ steps:
- cheatsheets-ja:
+ cheatsheets-fr:
image: *test_image
commands:
- - make -C build-docs/doc/po/ja local-cheatsheets
+ - make -C build-docs/doc/po/fr local-cheatsheets
- when:
- path:
- include:
- # Localized assets
- - "utils/check_localized_cheatsheets.sh"
- # Common docs path
- # related config files
- - ".woodpecker/docs.yml"
- # Makefiles
- - "doc/Makefile.in"
- - "doc/html/images/Makefile.in"
- # XML sources
- - "doc/*.xml"
- # Internationalization Makefiles
- - "doc/po/Makefile.local"
- # END OF COMMON PATHS
- # cheatsheets-ru:
- # commands:
- # - make -C build-docs/doc/po/ru local-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
-### TARGET check-cheatsheets
- # check-cheatsheets-it_IT:
- # commands:
- # - make -C build-docs/doc/po/it_IT local-check-cheatsheets
- # group: localized-check-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # check-cheatsheets-pt_BR:
- # commands:
- # - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- check-cheatsheets-fr:
- image: *test_image
- commands:
- - make -C build-docs/doc/po/fr local-check-cheatsheets
- group: localized-check-cheatsheets
when:
path:
include:
@@ -777,63 +293,18 @@ steps:
- # check-cheatsheets-es:
- # commands:
- # - make -C build-docs/doc/po/es local-check-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # check-cheatsheets-pl:
- # commands:
- # - make -C build-docs/doc/po/pl local-check-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- check-cheatsheets-ko_KR:
+### TARGET check-cheatsheets
+ check-cheatsheets-ja:
image: *test_image
commands:
- - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
+ - make -C build-docs/doc/po/ja local-check-cheatsheets
when:
path:
include:
# Localized assets
- - "doc/po/ko_KR/Makefile.in"
- - "doc/po/ko_KR/*.po"
# Common docs path
@@ -869,104 +340,11 @@ steps:
- check-cheatsheets-ja:
+ check-cheatsheets-fr:
image: *test_image
commands:
- - make -C build-docs/doc/po/ja local-check-cheatsheets
+ - make -C build-docs/doc/po/fr local-check-cheatsheets
- when:
- path:
- include:
- # Makefiles
- # XML sources
- - "doc/*.xml"
- # check-cheatsheets-ru:
- # commands:
- # - make -C build-docs/doc/po/ru local-check-cheatsheets
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
-### TARGET pdf
- pdf-it_IT:
- commands:
- - make -C build-docs/doc/po/it_IT local-pdf
- group: localized-pdf
- when:
- path:
- include:
- - "doc/po/it_IT/Makefile.in"
- - "doc/po/it_IT/*.po"
- # Makefiles
- # XML sources
- - "doc/*.xml"
- # pdf-pt_BR:
- # commands:
- # - make -C build-docs/doc/po/pt_BR local-pdf
- # group: localized-pdf
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- pdf-fr:
- commands:
- - make -C build-docs/doc/po/fr local-pdf
when:
path:
include:
@@ -985,63 +363,18 @@ steps:
- # pdf-es:
- # commands:
- # - make -C build-docs/doc/po/es local-pdf
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- # pdf-pl:
- # commands:
- # - make -C build-docs/doc/po/pl local-pdf
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
- pdf-ko_KR:
+### TARGET pdf
+ pdf-ja:
image: *test_image
commands:
- - make -C build-docs/doc/po/ko_KR local-pdf
+ - make -C build-docs/doc/po/ja local-pdf
when:
path:
include:
# Localized assets
# Common docs path
@@ -1077,17 +410,17 @@ steps:
- pdf-ja:
+ pdf-fr:
image: *test_image
commands:
- - make -C build-docs/doc/po/ja local-pdf
+ - make -C build-docs/doc/po/fr local-pdf
when:
path:
include:
# Localized assets
# Common docs path
@@ -1100,26 +433,3 @@ steps:
- # pdf-ru:
- # commands:
- # - make -C build-docs/doc/po/ru local-pdf
- # when:
- # path:
- # include:
- # # Makefiles
- # # XML sources
- # - "doc/*.xml"
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index ad9d2a172..991b4ec31 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -3,6 +3,7 @@
cd $(dirname $0)
SUPPORTED_LANGUAGES=$(grep ^translations ../doc/Makefile.in | cut -d= -f2)
+SUPPORTED_LANGUAGES="ja de fr" # restrict built translations
TARGETS="check-xml html cheatsheets check-cheatsheets pdf"
Summary of changes:
.woodpecker/docs.yml | 766 ++---------------------------------
.woodpecker/update-docs-localized.sh | 1 +
2 files changed, 39 insertions(+), 728 deletions(-)
hooks/post-receive
