[postgis-tickets] [PostGIS] #5471: upgrading demo.postgis.net is failing on st_coverageinvalidlocations when pg_upgrading in PG16
trac at osgeo.org
Thu Aug 10 20:42:45 PDT 2023
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.4.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Description changed by robe:
Old description:
> I was trying to upgrade demo.postgis.net to latest PG16 and it's failing
> because of this
> pg_restore: from TOC entry 943; 1255 17106 FUNCTION
> st_coverageinvalidlocations("public"."geometry", double precision) robe
> pg_restore: error: could not execute query: ERROR: could not find
> function "ST_CoverageInvalidLocations" in file
> "/usr/lib/postgresql/16/lib/postgis-3.so"
> Command was: CREATE FUNCTION
> "public"."st_coverageinvalidlocations"("geom" "public"."geometry",
> "tolerance" double precision DEFAULT 0.0) RETURNS "public"."geometry"
> LANGUAGE "c" WINDOW IMMUTABLE STRICT COST 5000 PARALLEL SAFE
> AS '$libdir/postgis-3', 'ST_CoverageInvalidLocations';
> -- For binary upgrade, handle extension membership the hard way
> ALTER EXTENSION "postgis" ADD FUNCTION
> "tolerance" double precision);
> Sadly our upgrade scripts don't catch this or drop it, so I have a broken
> install I can't upgrade.
> I think we need to add this tou our drop list, cause we changed this
> function midway in 3.4.0. Sure only reckless people like me would be
> impacted by this, but someone has to look out for us.
> The other annoying thing about this is I had to resort to using:
> /usr/lib/postgresql/16/bin/pg_upgrade -b
> /var/tmp/postgresql-16-202305211/bin -B /usr/lib/postgresql/16/bin -p
> 5432 -P 5433 -d /etc/postgresql/16/main.old -D /etc/postgresql/16/main
> instead of my preferred short-hand of:
> pg_upgradecluster 16 main.old --rename main -m upgrade -v 16 --old-
> bindir=/var/tmp/postgresql-16-202305211/bin
> Sadly for some reason pg_upgradecluster in this situation wipes out all
> the files it asks me to check for guidance.
New description:
because of this
Command was: CREATE FUNCTION "public"."st_coverageinvalidlocations"("geom"
"public"."geometry", "tolerance" double precision DEFAULT 0.0) RETURNS
"public"."geometry"
The other annoying thing about this is after doing:
pg_renamecluster 16 main main.old
su postgres
cd ~/
pg_dropcluster 16 main
pg_createcluster 16 main
/var/tmp/postgresql-16-202305211/bin -B /usr/lib/postgresql/16/bin -p 5432
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5471#comment:1>
