[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-11-g9376923fd
Thu Aug 10 20:51:45 PDT 2023
the project "PostGIS".
       via  9376923fdd6b5c62f25e5a1bb4a05064699670b6 (commit)
       via  f8f1076eeebb6065d40b546746240dd8e3db99cc (commit)
      from  d45a1fc48f25c7d25787f32fdfde947085ce3140 (commit)
revisions in full, below.
commit 9376923fdd6b5c62f25e5a1bb4a05064699670b6
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Aug 10 23:50:52 2023 -0400
    Drop ST_CoverageInvalidLocations
    was renamed to ST_CoverageInvalidEdges
    Closes #5471 for PostGIS 3.4.0
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index f901b22da..7968f5356 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -200,6 +200,10 @@ DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not confl
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry, integer); -- Does not conflict
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry); -- Does not conflict
+-- This was renamed mid-cycle in PostGIS 3.4.0 development
+-- to ST_CoverageInvalidEdges
+DROP FUNCTION IF EXISTS ST_CoverageInvalidLocations(geometry, double precision);
 -- geometry_columns changed parameter types so we verify if it needs to be dropped
 -- We check the catalog to see if the view (geometry_columns) has a column
 -- with name `f_table_schema` and type `character varying(256)` as it was
commit f8f1076eeebb6065d40b546746240dd8e3db99cc
Date:   Thu Aug 10 23:44:37 2023 -0400
    WINNIE LZ4 fix
     - When PG is compiled with Lz4 support
       it fails in LZ4 is not included in LDCONFIG
       and pkg-config.
       To fix, just always include it just in case it's
       needed
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index ddbc536cc..82e6e1fbb 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -59,7 +59,7 @@ if [$INCLUDE_MINOR_LIB == "1"]; then
 #LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
-LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
 ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
   --with-pgconfig=${PGPATH}/bin/pg_config \
@@ -71,7 +71,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
   #exit
 else
 ./configure \
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 558faf25b..9906d5659 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -72,7 +72,8 @@ if [$INCLUDE_MINOR_LIB == "1"]; then
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 ./configure \
@@ -84,7 +85,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${I
   #exit
 else
 ./configure \
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 396cdd58e..c01b9a1d5 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -22,6 +22,7 @@ if  [[ "${OVERRIDE}" == '' ]] ; then
 	export PROTOBUFC_VER=1.2.1
 	export JSON_VER=0.12
 	export PROJSO=libproj_8_2.dll
+	export LZ4_VER=1.9.3
 fi;
 export PROTOBUF_VER=3.2.0
@@ -63,7 +64,11 @@ fi;
 export CGAL_VER=5.3
 BOOST_VER=1.78.0
 export BOOST_VER_WU=1_78_0
-export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export LZ4_PATH=${PROJECTS}/lz4/rel-lz4-${LZ4_VER}w${OS_BUILD}${GCC_TYPE}
+export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
 #export GDAL_VER=2.4.0
 #export PROJ_VER=5.2.0
@@ -118,8 +123,13 @@ CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}
 export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+#add lz4
+export PATH="${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+echo $PATH
 export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${LZ4_PATH}/lib/pkgconfig"
 export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
Summary of changes:
 ci/winnie/build_postgis.sh         |  4 ++--
 ci/winnie/regress_postgis.sh       |  5 +++--
 ci/winnie/winnie_common.sh         | 14 ++++++++++++--
 postgis/postgis_before_upgrade.sql |  4 ++++
 4 files changed, 21 insertions(+), 6 deletions(-)
hooks/post-receive
