[postgis-tickets] [PostGIS] #5472: GEOS details seem wrong on demo.postgis.net
PostGIS trac at osgeo.org
Thu Aug 10 22:25:42 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I have no idea what happened here, but things appear to be good now.
 1) I had forgotten to upgrade tiger_2022 which had the same issue with the
 broken function
 2) I suspect maybe it was showing upgrade needed because I had compiled
 against the PG16 beta2, but the cluster was still at PG16 beta1.
 Anyrate now this shows:
 SELECT postgis_full_version(), version();
 POSTGIS="3.4.0dev 3.4.0rc1-11-g9376923fd" [EXTENSION] PGSQL="160"
 GEOS="3.12.0-CAPI-1.18.0" SFCGAL="1.3.8" PROJ="7.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.2.2, released
 2021/03/05" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
 PostgreSQL 16beta2 (Debian 16~beta2-2.pgdg110+~20230807.1057.ge8386b2) on
 x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110,
 64-bit
 I'm going to after attempt to do a distupgrade to at least bookworm so I
 can get a decent version of GDAL.  So many formats I'm missing like GTFS
 and Parquet cause this GDAL is so old.
 And damn I thought we'd be running beta3 that just came out, so might need
 to wait another week.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5472#comment:1>
