[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-12-gad03e3599
Fri Aug 11 13:43:29 PDT 2023
the project "PostGIS".
       via  ad03e35996b3b9c82a1a933fd2a6ef08f30ad578 (commit)
      from  9376923fdd6b5c62f25e5a1bb4a05064699670b6 (commit)
revisions in full, below.
commit ad03e35996b3b9c82a1a933fd2a6ef08f30ad578
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Aug 11 16:42:10 2023 -0400
    Regress output fix from Tobias Bussmann
    Closes #5470 for PostGIS 3.4.0
diff --git a/extensions/address_standardizer/expected/test-debug_standardize_address.out b/extensions/address_standardizer/expected/test-debug_standardize_address.out
index c4d62e004..70b2dfb40 100644
--- a/extensions/address_standardizer/expected/test-debug_standardize_address.out
+++ b/extensions/address_standardizer/expected/test-debug_standardize_address.out
@@ -1,5 +1,5 @@
 SELECT je->>'pos' AS pos, je->>'input-word' AS input_word, je->>'input-token' AS input_token, je->>'mapped-word' AS ouput_word, je->>'output-token' AS output_token FROM jsonb(debug_standardize_address('us_lex'::text, 'us_gaz'::text, 'us_rules'::text, '123 Main Street'::text, 'Kansas City, MO 45678'::text)) AS d, jsonb_array_elements(d->'rules'->0->'rule_tokens' ) AS je;
- pos | input_word | input_token | ouput_word | output_token
+ pos | input_word | input_token | ouput_word | output_token
  0   | 123        | NUMBER      | 123        | HOUSE
  1   | MAIN       | WORD        | MAIN       | STREET
@@ -7,32 +7,32 @@ SELECT je->>'pos' AS pos, je->>'input-word' AS input_word, je->>'input-token' AS
 (3 rows)
 SELECT jsonb_array_length(jsonb(d)->'rules') FROM debug_standardize_address('us_lex','us_gaz','us_rules', '10-20 DORRANCE ST PROVIDENCE RI') AS d;
- jsonb_array_length
+ jsonb_array_length
                   6
 (1 row)
 SELECT '#5299a' AS ticket, jsonb_array_length(d->'rules') AS num_rules, jsonb_array_length(d->'input_tokens') AS num_input_tokens,  d->'rules'->0->'raw_score' AS best_score FROM jsonb(debug_standardize_address('us_lex',  'us_gaz', 'us_rules','1 Timepiece Point','Boston, MA, 02220')) As d;
- ticket | num_rules | num_input_tokens | best_score
+ ticket | num_rules | num_input_tokens | best_score
  #5299a |         5 |                4 | 0.902500
 (1 row)
 SELECT '#2978c' As ticket, jsonb_array_length(d->'rules') AS num_rules, jsonb_array_length(d->'input_tokens') AS num_input_tokens,  d->'rules'->0->'raw_score' AS best_score FROM jsonb(debug_standardize_address('us_lex','us_gaz','us_rules', '10-20 DORRANCE ST, PROVIDENCE, RI')) AS d;
  #2978c |         6 |                5 | 0.751875
 (1 row)
 SELECT '#5299b' AS ticket, jsonb_array_length(d->'rules') AS num_rules, jsonb_array_length(d->'input_tokens') AS num_input_tokens, d->'rules'->0->'score' AS best_score FROM jsonb(debug_standardize_address('us_lex',  'us_gaz', 'us_rules','50 Gold Piece Drive, Boston, MA, 02020')) AS d;
  #5299b |         3 |                6 | 0.902500
 (1 row)
 SELECT '#5299bt' AS ticket, it->>'pos' AS pos, it->>'word' AS word,  it->>'token' AS token, it->>'stdword' AS stdword FROM jsonb(debug_standardize_address('us_lex',  'us_gaz', 'us_rules','50 Gold Piece Drive, Boston, MA, 02020')) AS d, jsonb_array_elements(d->'input_tokens') AS it
 WHERE it @> '{"pos": 2}'::jsonb;
- ticket  | pos | word  | token | stdword
+ ticket  | pos | word  | token | stdword
  #5299bt | 2   | PIECE | UNITH | PIECE
  #5299bt | 2   | PIECE | UNITT | PIECE
@@ -40,7 +40,7 @@ WHERE it @> '{"pos": 2}'::jsonb;
 (3 rows)
 SELECT r->>'score' AS score,r->>'rule_string' AS rule, r->>'rule_stub_string' AS rule_stub  FROM jsonb(debug_standardize_address('us_lex','us_gaz','us_rules', '25 Prince Street, NC 09985')) AS d, jsonb_array_elements(d->'rules') AS r;
-  score   |          rule          |      rule_stub
+  score   |          rule          |      rule_stub
  0.902500 | 0 1 2 -1 1 5 6 -1 1 16 | 0 1 2 -1 1 5 6 -1 %
  0.791875 | 0 1 2 -1 1 5 6 -1 1 16 | 0 1 2 -1 1 5 6 -1 %
Summary of changes:
 .../expected/test-debug_standardize_address.out            | 14 +++++++-------
 1 file changed, 7 insertions(+), 7 deletions(-)
hooks/post-receive
