[postgis-tickets] [PostGIS] #5473: Building without-pgconfig errors out and might be going in an infinite loop
trac at osgeo.org
Fri Aug 11 21:58:33 PDT 2023
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.4.0
Component: loader/dumper | Version: master
Keywords: |
When I build with ./configure --without-pgconfig on my mingw64 setup
It errors:
make[374]: *** [Makefile:28: all] Error 2
make[374]: Leaving directory '/projects/postgis/postgis-git/raster'
make[1]: Leaving directory '/projects/postgis/postgis-git/raster'
make: *** [GNUmakefile:25: all] Error 1
I'm thinking this might be happening on woodie too why it keeps crashing
on the tools even when the tools agent job was running on the woodie-
server. I saw the server docker process die. I tried moving the tools job
to dronie, and she didn't like it either.
I'm going to try some other machines to see if the behavior repeats.
I've also attached one log file I managed to pull from woodie, before it
kicked the can. Looks like the same thing
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5473>
