[postgis-tickets] [PostGIS] #5473: Building without-pgconfig errors out and might be going in an infinite loop
PostGIS trac at osgeo.org
Fri Aug 11 22:24:18 PDT 2023
  Reporter:  robe           |      Owner:  strk
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 3.4.0
 Component:  loader/dumper  |    Version:  master
Resolution:                 |   Keywords:
Comment (by robe):
 Okay I see the problem.  My generated makefile when I'm building without-
 pgconfig
 looks like this:
 all:
         $(MAKE) corelib
         $(MAKE)
         $(MAKE) rtloader
         $(MAKE)
 because you changed the code to
         all:
           $(MAKE) @RT_CORE_LIB@
           $(MAKE) @RT_PG_LIB@
           $(MAKE) @RT_LOADER@
           $(MAKE) @RT_POSTGIS_SQL@
 and there is no RT_PG_LIB or RT_POSTGIS_SQL if you are building --without-
 pgconfig
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5473#comment:4>
