[postgis-tickets] [PostGIS] #5474: 3.4.0-rc2 fails to build (test failures)
PostGIS trac at osgeo.org
Sat Aug 12 02:26:44 PDT 2023
 Reporter:  Bas Couwenberg         |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  high                   |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 The
 [https://buildd.debian.org/status/package.php?p=postgis&suite=experimental
 Debian package build] for 3.4.0-rc2 fails due to test failures:
  /<<PKGBUILDDIR>>/regress/core/flatgeobuf .. failed (diff expected
 obtained: /tmp/pgis_reg/test_17_diff)
 --- ./regress/core/flatgeobuf_expected  2023-08-12 06:12:41.000000000
 +0000
 +++ /tmp/pgis_reg/test_17_out   2023-08-12 08:58:31.031006772 +0000
 @@ -1,3 +1,4 @@
 +ERROR:  invalid value for parameter "TimeZone": "utc"
  --- Null geometry ---
  T1|0|
  --- Geometry roundtrips ---
 Full buildlog:
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=amd64&ver=3.4.0%7Erc2%2Bdfsg-1%7Eexp1&stamp=1691830827&raw=0
 amd64],
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=arm64&ver=3.4.0%7Erc2%2Bdfsg-1%7Eexp1&stamp=1691831167&raw=0
 arm64],
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=ppc64el&ver=3.4.0%7Erc2%2Bdfsg-1%7Eexp1&stamp=1691830709&raw=0
 ppc64el]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5474>
