[postgis-tickets] [PostGIS] #5476: winnie's build script is broken
trac at osgeo.org
Sun Aug 13 17:29:15 PDT 2023
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.4.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by robe):
okay looking at my build folder, looks like last time all extensions could
install was on 8/10.
And it seems it's only the postgis_tiger_geocoder, address_standardizer,
postgis_topology that can't install, cause if I explicitly go into each of
the extensions folders, I can install the others
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5476#comment:3>
